Old 12-18-2015, 09:05 PM   #1
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
Pics of my build so far.
She came from Stilwell, OK. I bought her from a gentleman in AR.
Hopeless Busaholic!
Roadrunner is offline   Reply With Quote
Old 12-18-2015, 09:20 PM   #2
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
More pics.
She came without seats, saved me lots of work.
My new best friend.
Hopeless Busaholic!
Old 12-18-2015, 09:24 PM   #3
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
More.
How they managed to flatten all the heater core fins under a seat cushion is beyond me. It took a long time to get them somewhat back to normal.
Hopeless Busaholic!
Old 12-18-2015, 09:30 PM   #4
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
More.
To get the windows out I cut the sealant on the outside. Then used a screwdriver to get the top loose then pulled HARD. That is not an easy job.
Hopeless Busaholic!
Old 12-18-2015, 09:37 PM   #5
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
More.
I was surprised that there wasn't any plywood on the floor, just rubber on metal. To loosen the rubber I used a tool called a long reach air scraper. It came from Harbor Freight. What a time-saver. It lists for $119.00 but it is worth it. Especially when you borrow it. I did the whole floor in about three hours. It is basically a long handled air chisel. I highly recommend using one. It loosens the rubber like nothing.
Hopeless Busaholic!
Old 12-18-2015, 09:42 PM   #6
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
More.
After I had the rubber removed from the floor I used a wire brush on a small grinder to remove the old sealant where the walls meet the floor and the floor seams. Use protective equipment, believe me. It does a great job.
Hopeless Busaholic!
Old 12-18-2015, 10:03 PM   #7
Great start...keep the pix a'comin'!
Old 01-11-2016, 08:45 PM   #8
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
Some more pics.
Man, this is getting to be too much like work. I've been cutting the insulation for the roof into strips and putting a bevel on them because of the curve of the roof. It wouldn't be so bad if it wasn't for the coating of fiberglass on the sheets. I've been using the table saw and jig saw and end up getting coated with fiberglass. ITCHY! I keep telling myself it will be worth it in the end. It sure makes a mess inside the bus too. Plus it has been below zero or in the single digits and then in the teens during the day. I wish it wasn't so chilly. I'll just keep plugging away.[URL=http://s428.photobucket.com/user/TheHappyBus/media/IMG_0109_zpslm0oszco.jpg.html]
Hopeless Busaholic!
Old 01-11-2016, 08:47 PM   #9
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
One more.
Hopeless Busaholic!
Old 01-14-2016, 09:51 PM   #10
go00nascar's Avatar
Engine: 5.9 Cmmins
Rated Cap: 71
Good job so far. Give us some info. on your bus, year , engine....
looks a lot like mine. other than mirrors.
I'm not getting much done because of cold. I'm about 175 miles west of you. highs in 20s next week Brr
go00nascar is offline   Reply With Quote
Old 01-14-2016, 10:23 PM   #11
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
Hi go00nascar. My bus is a 1999 BB TC2000 with a 5.9 Cummins. I'm in the same boat as you with the cold. We are supposed to have a heat wave tomorrow in the mid forties. The weather said next week we will get the coldest temps. of the season and we've already been below zero so it doesn't look too promising. I'm sure you know what I mean as you normally get it a day or so before I do. I'll do my best to keep plugging away. I still have lots to do before the roof raise. If you need anything holler.
Hopeless Busaholic!
Old 02-20-2016, 11:57 PM   #12
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
A little progress on the insulation.
Hopeless Busaholic!
Old 03-08-2016, 08:47 PM   #13
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
Finally some more progress.
[URL=http://s428.photobucket.com/user/TheHappyBus/media/IMG_0179_zpsvfxv2d75.jpg.html]
Hopeless Busaholic!
Old 03-08-2016, 08:53 PM   #14
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
One more.
Hopeless Busaholic!
Old 03-08-2016, 09:16 PM   #15
Lookin' good! Keep it up.
Old 03-08-2016, 10:27 PM   #16
Skoolydoo's Avatar
Rated Cap: 2+1
I just seen pictures of your bus, the difference between yours and mine is the name badge
And that Crow above the drivers window.lol
Really you are coming along nicely. I sure wish I was that far. I think I will get me one of those long air chisels..it's worth the money with time saved..plus maybe you could sell it to the next guy that is doing a conversion, get some money back and help a new skoolie.
Don and Ellen
Plus one fuzzy faced kid (Poopcee)
Skoolydoo is offline   Reply With Quote
Old 03-20-2016, 11:06 PM   #17
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
More pics and roof raise.
Hopeless Busaholic!
Old 03-21-2016, 06:46 AM   #18
Way to go man!
Old 03-21-2016, 08:25 AM   #19
Skoolydoo's Avatar
Rated Cap: 2+1
Wow, I'm impressed you really have been busy. From the pics looks like the weather has been in your favor..
Get that call you been waiting on? If not you can stay busy, or it sure looks like you can.
Keep the pictures coming.
Don and Ellen
Old 03-21-2016, 08:40 AM   #20
Engine: Cat 3126e
Rated Cap: 28
Great Job!!! Looks fantastic!
Keep it up!
Josiahdr is offline   Reply With Quote
