Old 08-09-2018, 12:14 PM   #191
brokedown's Avatar
Almost as bad as owning a boat!
Did I mention i sold my boat?
Follow us on Facebook, Instagram, and Twitter
Old 08-09-2018, 08:16 PM   #192
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
Accufab came back with a $750 quote.
Better but still higher than I had expected.
After reading about the guy who found duraplate pieces from his local trailer place I went to MY local trailer place and MAJOR SCORE! If I take my own tools and safety equipment I can cut pieces of duraplate off a wrecked trailer. They were also willing to put takeoff pieces aside for me, but this will actually be easier and there are some airhose fittings and plywood that I can salvage as well. I am so excited. It may be better for the windows than the emergency hatches, but the doors are thicker so maybe they would work?
Duraplate is aluminum skinned on both sides of a composite interior. It's what they may truck trailer walls and doors out of.
I also discovered that the big boys use dow froth packs for their spray foam insulation. They said reefers use 2" of that with the duraplate walls and doors. They have a really cool foam trimmer that looks sort of like a reel mower blade. Maybe if I take the shop some baked goods when I go scavenge duraplate they will let me come back and use their trimmer...... they said I can cut it with a circular saw with a blade with small teeth or a Sawzall.
I think this will work just as well as the sheetmetal I got for the first few windows and save me a ton of money.
2martins is offline   Reply With Quote
Old 08-09-2018, 10:44 PM   #193
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
good for you
I would add a blender with ice cream to go with the cookies... milkshakes....
but i go overboard....often.
william
Old 08-15-2018, 01:48 PM   #194
Looks like Accufab:
qty length width price cost
2 68 41 $65.79 $131.58
4 59 41 $52.92 $211.68
2 66 41 $59.20 $118.40
2 73 41 $65.48 $130.96
2 57 41 $51.13 $102.26
Sub-Total $694.88
Tax $61.84
Total $756.72
Going to cover two window openings at a time.
Old 08-15-2018, 02:14 PM   #195
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
I skinned the outside of the Bluebird with prepainted white aluminum repair panels for semi trailers they are 49"x110" I paid $476.00 for 7 of them delivered to where my son works.I have 1 left for making the end caps where I raised the roof.the installation was straight forward. I did it by myself and I cut it with a circular saw fitted with a 60 tooth carbide blade set a twice the depth of the material. EZ peasy
Gdog 5651 is offline   Reply With Quote
Old 08-15-2018, 02:26 PM   #196
Chassis: Bluebird
Rated Cap: 74
I forgot to add that because it is prepainted one avoids the problems associated with finishing aluminum, even if you don't like the color or you want graphics you just tape it off hit it with a fine scotchbrite pad and paint it like you would anything else. Gene
Old 08-15-2018, 02:37 PM   #197
Thanks Gene for the suggestion.
I have decided to stick with steel.
There were some repairs that had been done to my bus using AL rivets in steel panels. After my experience with those I decided to avoid dissimilar metals as much as I am able.
Old 08-15-2018, 02:39 PM   #198
Rivets
I just got off of the phone with a REALLY helpful gentleman who is very knowledgeable regarding rivets and their application in skoolies.
From e-Mail: kevin@rivetsinstock.com
From Company: Jay Cee Sales & Rivet, Inc.
From Phone Number: (24 478-2150
From Fax Number: (24 478-6416
Edit: When I edit this the phone numbers show up properly... 248 area code...
Old 08-15-2018, 02:41 PM   #199
You did......
I was looking forward to going sailing when we get there..... Charter works
Edit: Captain Hillary needs to get healed up first!!
Old 08-31-2018, 08:05 AM   #200
Brewerbob's Avatar
Engine: 8.3L Cummins ISC 260hp, AT643, 4.44 rear
N
I was going to try that. Unfortunately I have moved and don't have access to suitable trees any more. I have one tree in my new yard and I am concerned about it's health. It may be coming down this year.
You were out in the sticks right? When did you move? Am I losing (what little) mind I have left? Didn't you live in a bus that was the fishing bus?
I'll mutli-post the rest of my comments as I read thru your thread.
