Old 10-03-2018, 06:40 PM   #221
PROGRESS.....
Almost done with the last piece of big metal on the sides.
I am so blessed to have a Wife with a great attitude. When I got so frustrated trying to get stuff done by myself and trying real hard to make a trip to the emergency room.... She jumped in and gave me a hand hanging the metal.
Old 10-03-2018, 07:52 PM   #222
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Looks awesome
Nice job man!
Old 10-03-2018, 07:53 PM   #223
Yeah man, looking forward to seeing the rest of it!
Roll Your Own Build Thread
Old 10-22-2018, 07:03 PM   #224
Thank you for the compliments!!
Today's progress.... A gallon of SEM self-etching primer applied to the new metal.
Unfortunately we are having a huge outbreak of aphids and many of them met their death in my primer.
What grit sandpaper is appropriate for sanding dead aphids?
Old 10-23-2018, 08:22 AM   #225
Brewerbob's Avatar
Engine: 8.3L Cummins ISC 260hp, AT643, 4.44 rear
I dunno if I already mentioned this or not. Hell, I may have even poo-pooed the idea back then but I wish I had seen the front cut before I had cut mine. That looks like it's going to be SOOOOO easy to put back together again. Two extra rows of rivets might look goofy but it's going to be much easier to fab.
I think I figured out how I'm going to fix the butchered ribs. The plan at the moment is to use two squares on the outside of the existing two. Weld those to a piece of flat steel that's thick enough for support but thin enough to get a 3/8" length rivet thru.
Aside from the metal possibly wanting to move while cutting, I don't see any reason why I can't cut the sheet metal, reattach, and put back together like you're doing.
Old 10-23-2018, 08:43 AM   #226
Brewerbob's Avatar
P.S. Do you have/can you take more pics of the rib structure in the front corners? Pictures of the rear with the cut-down? And the framing in the rear?
Old 10-23-2018, 07:48 PM   #227
Only the pics that I have posted. I need a staff photographer.... Asetechrail took more pics while we were working than I did.
I have not started framing the back yet. I will post photos as soon as I do.
Old 10-24-2018, 09:33 AM   #228
Brewerbob's Avatar
Not seeing any pics from Asetechrail either. :/
Old 10-31-2018, 05:56 PM   #229
Where I could, I nested square tube inside of the rectanglular tube and plug welded.
http://www.skoolie.net/forums/f11/pn...tml#post288913
Where I could not, I placed two pieces of angle on the outside of each rectangular tube.
Old 11-01-2018, 07:22 AM   #230
Brewerbob's Avatar
I'm guessing the door changed between mine and yours. That's really neither here nor there but I'm wondering if the framing is different too.
1" square tube will fit in mine I think. I need to chop a couple inches off and fit check it.
I didn't see any pics of the angle iron.
