05-31-2018, 06:05 PM
#161
Originally Posted by 2martins
What are you going to use for defroster heat?
I left the original driver's area heater/defroster. I am going to run new coolant lines along the frame rails to the front of the bus.
06-06-2018, 11:10 PM
#162
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
Mine is seriously nasty. I can't clean the fins (or whatever you call those metal things at the back) well. But there's no point in replacing them with something else that I can't clean and has no air filter. The original one was actually open to the area under the dash due to a significant crack in the housing where it wasn't lined up right. I can use sikkaflex or something on it and maybe it won't get AS gross. I used compressed air to blow it out as well as I could....
08-01-2018, 03:06 PM
#163
Finally getting back to some bus work.
I REALLY got spoiled having Asetecrail helping me out. After working with him on the roof raise I find that working on by myself is not nearly as much fun. Kent, your assistance has been MUCH appreciated!! When you get back to WW we need to have dinner again.
But I am back at it and fooling with sheet metal. I am puttering with how the new metal will fit into the existing metal. I stuffed a piece up under the roof metal, drilled a hole and attempted to place a cleco. Didn't play so well...
The roof metal is pulled far enough away from the hat chanel that the clecos are too short and too stiff to bend easily back in place. I need to such the roof metal back in place so that I can rivet it. Is there a special tool for this?
Any suggestions?
Thanks.
S.
08-01-2018, 03:41 PM
#164
Chassis: Blue Bird
Engine: ISC 8.3
EDIT: removed comments about getting the new exterior sheet hung on the walls. That was done and fully riveted before I did anything about fastening the roof edge down, which is what Steve asked about.
I went inside the bus and located in the C-shape header at the top of each bay (between vertical hat channels) where the original line of rivets at the bottom edge of the roof metal had been. I drilled 2-3 of these through from inside toward outside.
Finally I went back outside the bus and pushed a #10x1 inch machine screw through the existing rivet hole in the roof metal, through the newly-drilled hole in the new wall sheet, and through the existing hole in the C header. An assistant on the inside put a nut on it and we spun it down snug. Repeat for the other two holes drilled above.
That took the roof metal down close enough that I could drill the remainder of the holes and buck rivets into all of them, removing the machine screws at the appropriate time.
08-01-2018, 04:57 PM
#165
Great description! I can visualize almost all of it. One clarification: do I understand correctly that you put the metal in place then riveted the sides followed by the top?
Thanks.
S.
08-01-2018, 04:59 PM
#166
Just got my first quote back on metal to cover the windows. Only the windows.... Not the front or rear cap metal.... $995.04 plus tax.......
Only about double of what I expected. Waiting on additional quotes and hoping for a better deal.
08-01-2018, 06:19 PM
#167
Metal quote #2 - $923 plus tax.....
08-01-2018, 06:44 PM
#168
Self tapping screws are often used to pull the metal into shape for riveting.
08-01-2018, 07:17 PM
#169
Good thought but there is not a good spot along the top to put the screws in the spot that I need to manipulate. It is at the very bottom of the roof metal and I have the goofy "rain shades", or whatever you want to call them, to deal with. There is pretty much only room for the two rivets. one on each side of the hat chanel.
08-01-2018, 07:45 PM
#170
I can't picture it in my mnd. Could you have stated from the other end of the metal? Start securing the end that needs manipulating first?
08-01-2018, 08:20 PM
#171
Just wondering if there might be a way to rig ratchet strap(s) to get you started riveting. Attach a couple of slings with eyes somewhere and draw the ratchet up as tight as you need it.
08-01-2018, 08:24 PM
#172
Dang, I could get you the steel and ship it for that. Or maybe even less!
#173
That's what I used to cover the roof hatches. And my front transition "cap".
08-01-2018, 08:29 PM
#174
Credit goes to you for that idea my man! , thought I had seen that someplace. Did you have to weld rings on for the hooks or how did that work?
08-01-2018, 08:36 PM
#175
Rated Cap: 34
Is there a Metal Supermarket anywhere near you? I've found their pricing is better than anyone else's in my area.
08-01-2018, 09:28 PM
#176
Nah, just used whatever was available to grab hold of.
08-01-2018, 09:43 PM
#177
I may have to post a picture to illustrate.
There are two rivets in the roof metal between each "eyebrow". This is where I am having trouble. There is one rivet on each side of the hat channel that sits between the eyebrows.
I need to pull that portion tight.
08-01-2018, 09:49 PM
#178
I wish......
I am in a remote rural community. We have 5000 people in the county. Two towns and one stop light in the entire county.
08-01-2018, 09:52 PM
#179
I know. It sucks.
I can drive 5 hours to Seattle and get it for half the price. Then add time and travel costs and it is not a bargain.
08-01-2018, 10:06 PM
#180
Rated Cap: 34
I wish......
Well....on the bright side....you probably have the nicest bus in the entire county.
