Old 03-28-2015, 09:51 AM   #11
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 8 Assengers 2 ATV's
Good job, how long did it take you to get to this point?
Old 03-29-2015, 10:27 AM   #12
Andru & Chuck ~ Thank you. I'm glad that you are able to take some ideas/tips from my conversion. I started out with the kitchen countertop and worked everything else out around that. I honestly changed the plans/layout over a dozen times while doing the conversion. it was really fun though.
if there is anything I can do to help feel free to ask.
Quincey MS
Quincey MS is offline   Reply With Quote
Old 03-29-2015, 10:38 AM   #13
REDD~
it took me a year and four months. that was just weekend work and not working on it over the winter months though. so I probably put a total of 2 months of solid work into it all combined. I did it all by myself too except for the electric panel hook up and some minor welding. it would go by far easier and faster with a helping hand.
I still have to paint the exterior, instal an rv door, roof deck and a rear rack to put on. then I have a few things to finish up on the inside. the drivers switch panel area, bluetooth stereo, removing the flooring and installing a better quality of flooring. the winter causes the current flooring to buckle up a bit. that's what I get for going the cheap route though.
trial and error.....
not too bad for my first conversion though. it was a lot of fun for sure!
