12-04-2012, 06:33 PM
Year: 1987
Engine: 6.9L
Rated Cap: 71
Post Deleted
Thread Deleted
12-05-2012, 09:34 PM
Year: 1987
Engine: 6.9L
Rated Cap: 71
Re: Post Deleted
Thread Deleted
12-06-2012, 09:35 AM
Re: The Living Bus Project
BMP --- Welcome! And this will no doubt be an interesting build worth following.
12-06-2012, 04:20 PM
You wouldn't happen to be an engineer, would you?
Brutus
12-06-2012, 07:52 PM
Year: 1987
Engine: 6.9L
Rated Cap: 71
Re: Post Deleted
Thread Deleted
12-06-2012, 08:18 PM
That's awesome!! We are in the process of becoming debt free to do the same. Only about one more year to go. And yes, lol...I am a service technician for an automated packaging machinery company and work with engineers on a daily basis. There was no doubt.
Brutus
12-06-2012, 08:49 PM
Rated Cap: 89
LP STORAGE: Two propane tanks are mounted underneath with a total 100lb total capacity. This will last about a year of continuous use with a LP stove.
Two questions... where did you get 50lb horizontal LP tanks (not that I want one, just curious) and what LP stove are you using. I know that my LP gas range (30" GE Profile) uses far less LP (currently using about 27 GALLONS per year or 115 pounds) than the small RV gas range we used in the Class C. Others may want to know a good energy efficient alternative to the common RV ranges.
100 gallons of propane weighs 424 pounds (4.24 lbs. per gallon) so 100 lb tanks = 23.5 LB
12-06-2012, 10:30 PM
Year: 1987
Engine: 6.9L
Rated Cap: 71
Re: Post Deleted
Thread Deleted
12-07-2012, 09:33 AM
First off, I hugely respect your ability to calculate all this and recognize the amount of thought that goes into it. I hope you are able to achieve your goals, but I want to remind you of an important variable that you are forgetting. Real life. It is to be applied at a ratio if .5, so is therefore a very simple equation ;). I'm not trying to be negative, but I can almost promise that most of what you have figured here will not be achieved as expected. The HP and torque increases you stated for your engine for example, while they may actually prove true, as they are hopefully dyno proven, the real world gains will likely be half. Why? Because there are too many variables to account for when moving something this heavy, this wind resistant, and with this much drivetrain loss down the road. Real life ALWAYS kicks you in the ass. Anywho...I have blabbered enough. Definitely looking forward to watching your progress.
Brutus
12-16-2012, 01:54 PM
Chassis: IH
Engine: 466
Rated Cap: 64
Will look forward to MPG figures when you get it all assembled and running down the road!
12-20-2012, 02:16 PM
Year: 1987
Engine: 6.9L
Rated Cap: 71
Re: Post Deleted
Thread Deleted
12-20-2012, 02:19 PM
Awesome! Luckily it doesn't cost much either.
12-20-2012, 02:58 PM
not to sound as a downer (i really want to see this ride out )
it will end up being a $1,000,000.00+ Skoolie when it's all said and done....cool...but $$$$$
12-20-2012, 03:08 PM
Engine: DT466/AT545
17 stage water filtration?! Dude, are you completely insane? I hope so! Please keep us in the loop as your condition progresses - this looks to be a lot of fun.
12-20-2012, 04:59 PM
Year: 1987
Engine: 6.9L
Rated Cap: 71
Re: Post Deleted
Thread Deleted
12-20-2012, 05:03 PM
I agree water is more important than food,
So you can actually buy "off the shelf" this water system for that price?
Just curious cause this way cool...oops with a "K" Kool
12-20-2012, 09:09 PM
Believe I would just double distill and be done with it. Just my two cents worth because I believe "KISS" makes sense--but then I have a very small bus and would need a trailer to haul your proposed system (which I agree will work just fine).
12-20-2012, 10:27 PM
Personally I plan on using dehydrated water. It's lighter & takes up so little space.
12-21-2012, 12:08 AM
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
My vote is for whiskey or tequila.
02-01-2013, 12:37 AM
Chassis: All American RE
Engine: 3208TA Cat 250HP
Looking forward to this build... Welcome!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Account deleted?
karlw |
Everything Else | General Skoolie Discussions |
4 |
09-19-2013 11:01 AM |
Post deleted...
phillbus914 |
5 |
07-16-2008 10:55 AM |
BUS FOUND-NOTICE DELETED
Demonknight |
Classifieds | Buy, Sell, Swap |
1 |
05-07-2005 11:05 PM |
Deleted by author
Les Lampman |
4 |
03-24-2004 08:44 AM |
