Old 10-25-2013, 10:43 PM   #441
Re: Project "Brutus"
When you blew the tire, did you have a spare and was it on a rim when coach net changed it? or did they have to mount it on the rim for you?
tks
Old 10-26-2013, 10:21 AM   #442
JakeC's Avatar
The spare was on the rim, but he actually took it off and put it on the existing rim. He said it was easier and he liked to avoid jacking it up on the side of the road if possible.
Brutus
Old 10-26-2013, 10:59 AM   #443
Chassis: Ward
Engine: 6.6L Brazilian Ford
Rated Cap: 1
Jake,
What's your ETA home? You been gone awhile already. I'm starting to get vacation envy!
Bus Transformation: My CHEAP project >>> viewtopic.php?f=9&t=466640
gus
gusbus is offline   Reply With Quote
Old 10-26-2013, 10:42 PM   #444
JakeC's Avatar
Tomorrow night. The fun is coming to an end... :/ For now
Brutus
Old 10-27-2013, 10:00 AM   #445
Year: 1974
Engine: Detroit Diesel 6-71
Originally Posted by wmkbailey
How did you get coach-net? When I applied, I was turned down. They wont take school buses.
I did mine online, when they asked for model i just clicked other and typed in my model and motor. No mention of it being a school bus originally. Don't forget, you're not driving a school bus, it's an RV!
Proud new owners of a 1974 Crown Supercoach - the big rolling twinkie!
viewtopic.php?f=9&t=466562
inkblots84 is offline   Reply With Quote
Old 10-27-2013, 04:19 PM   #446
JakeC's Avatar
Yep! Same here.
Gus!! Why is your state so windy?!? Lol!
Brutus
Old 10-27-2013, 09:01 PM   #447
Chassis: Ward
Rated Cap: 1
It got that way after the tree removal project was over
It's funny, both times you came through have been some of the windiest I've seen this year.
You hit it just right both times!
gus
Old 10-28-2013, 03:03 PM   #448
How in the world would changing the tire from rim to rim on side of the road; be easier than changing an outside dual on the pass side?
Drive up on block (inside tire) zip...zip...replace mounted tire and tighten lugs....drive off blocking
please edujuuummecate me
I also have coach net...haven't needed yet...knock on wood...knock,knock
Old 10-28-2013, 03:40 PM   #449
JakeC's Avatar
Lugs are holding both wheels on. Removing the lugs would free inside wheel as well and allow it to cock sideways, I would imagine. At least that is what I am picturing. It only took him about 30 minutes.
Finally home!! Wish I wasn't though :/ Tons of pics to upload
Brutus
Old 10-28-2013, 04:07 PM   #450
actually there is an inside and out side lug nut (on mine at least) are you saying he mounted the tire w/o taking it off even? do you have video?
Old 10-28-2013, 05:58 PM   #451
It can be done...how big tractor tires are changed...you have a tool that clamps on the rim to break the bead.
caleath is offline   Reply With Quote
Old 10-28-2013, 06:01 PM   #452
Those are budd wheel studs by the way...you have to have a socket to take that outer nut off...its rh thread...then you need another socket to take that square shaped stud out...its lh thread to remove the inner wheel...just in case you need to take it off in the future
I am sure looking forward to seeing your pictures...i check your thread a few times a week.
Old 10-28-2013, 06:54 PM   #453
JakeC's Avatar
Thanks!! You just cleared up a big question in my head on how it works with the stud and the lug nut. I was gathering there was more to it than I thought. So do the outer and inner wheels have different size mounting holes? No video, Bansil, but I have pics!
Brutus
Old 10-28-2013, 07:05 PM   #454
Cool, when I got my spare....I asked the tire guy for just a tire and he said "cheaper and easier to just tire/wheel combo"...cost like $50 for non retread used tire and a wheel mounted
Now I'm thinking wow.....
Post more pics when you get a chance.....your tire change is at opposite end of universe from mine before the trip
Old 10-28-2013, 07:39 PM   #455
Chassis: Ward
Rated Cap: 1
Looks like that dern tire messed with the paint a little
gus
Old 10-29-2013, 07:59 AM   #456
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
NO, wheels are both the same.
Here's a picture of inner and outer nuts.
Old 10-29-2013, 09:42 AM   #457
JakeC's Avatar
Ahhhh...a stud screwed over a stud and a nut screwed over that. Cool!! I should have just googled it, but I was too busy being lazy
Brutus
Old 10-29-2013, 09:44 AM   #458
JakeC's Avatar
Just loaded the pics from my phone to photobucket. Still have to get pics off my camera. I'll get 'em!
Yep, but it will be easy to touch up...
Brutus
Old 10-29-2013, 10:08 AM   #459
JakeC's Avatar
Couple pics at the resort...rough life.
My wife is intensely afraid of heights. I asked her if she thinks gravity is going to go sideways and suck us off the mountain. This was me acting that out. She was actually mildly humored. We were in a rental here, but driving the bus she would go hide in the back at some points. I felt bad for her and drove like a saint (not sarcastically, tried to make it as smooth as possible for her)
Pics from a random road we ended up on...
Didn't like my mirror mounts, as they were designed to have 2 mirrors on each side for safety. I had removed the 2 showing the front of the bus, but still had to use the goofy brackets. So, I broke out the welder before we left. Went from this...
to this...
Burney Falls, near Mt. Shasta
View from Mt. Shasta
Redwood forest...hard to capture!!
Ocean!
Heading home... This is after the tire blow out.
At a pullout, heading into the Tetons!
Tetons...
These are all off my phone... Camera pics tonight.
Brutus
Old 10-29-2013, 10:38 AM   #460
Chassis: Ward
Rated Cap: 1
Nice pics Jake!
I have a sister that gets petrified when traveling in the Mtns. too! Scary stuff I guess; for some!!
gus
Project "Freedom" ratty2austin Skoolie Conversion Projects 15 10-01-2014 10:46 PM
Project "Eco Bus" travelinwithus Skoolie Conversion Projects 1 05-11-2013 01:13 PM
"Short" bus or "Regular" bus? TygerCub Conversion General Discussions 11 03-03-2012 12:37 PM
"Tutorial" and "How To" internal error dunnwright Conversion General Discussions 6 11-16-2010 07:02 AM
