Old 12-13-2013, 10:20 PM   #31
Re: Project Transformation
Very cool...or...warm. Either way it must make a HUGE difference.
Old 12-20-2013, 08:24 AM   #32
Chassis: Ward
Engine: 6.6L Brazilian Ford
Rated Cap: 1
OK,
Today I'm headed home for the holiday's and won't be back to work until January 6. I'm taking the bus home and doing some work on it on my time off. The trip is 450 miles. This will give me some idea what kind of mileage it will get. I have a friend that gave me a pile of 4" pine flooring. As much as there is it will justify the trip home. I'm going to put up pine flooring everywhere until I run out or get the bus done; one or the other.
It's -8 here this morning so the bus will need some coaxing to get `er going but it has a record of starting if you can recreate the right conditions. The pics that follow kind of sum up where I'm at with it. It needs sheeting now.
One thing I forgot to mention is that when I had foam sprayed under the bus the guy sprayed the wheel wells too; I forgot to tell him not to. Not sure how that will work going forward and adding weight but right now there is a good 5-6" of clearance between the wheels and the insulation.
Bus Transformation: My CHEAP project >>> viewtopic.php?f=9&t=466640
gus
gusbus is offline   Reply With Quote
Old 12-20-2013, 11:03 AM   #33
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Thats ok the tires will wear out just what they need
Old 12-21-2013, 08:47 AM   #34
SAFE TRAVELS!!! and Happy Holidays
Talk about bringing a hobby along to kill some time
If you don't mind- how much did it cost to get the under side spray foamed and how thick?
In my planning/thinking the foam underneath would need some kind of protection from road wear. I started to look into roll-on or spray-on bed liners (diy of course) for this purpose. I guess we'll all find out when you get back- safely of course.
RedBone is offline   Reply With Quote
Old 12-21-2013, 11:41 AM   #35
Chassis: Ward
Rated Cap: 1
I made it home last night about 9:30; the trip was uneventful and the bus ran out good. I stopped at my brothers place, about 100 miles into the trip, and we changed all three fuel filters. It had not been done for years and I'm sure and it needed it. We also replaced the primer pump on the fuel pump as it wasn't working. My brother is a diesel mechanic so this was all just routine stuff for him, besides, he has a nice shop on his farm.
The insulation under the bus is around 4" thick. However, I doubt the insulation in the wheel wells is more than 2". The cost to have someone else do it was $600.00. I couldn't buy the materials, myself, to do it for less than that price. This spray foam has a coating on it like the spray foam roof materials you see. I suppose you could spend the extra money to give it more protection but I don't forsee driving it enough to justify the extra protection.
As far as MPG; I can only speculate as to that because I've not filled up yet again. I've got a 1/4 tank left after the trip but have no solid numbers as to the tank size yet. I'm assuming it's around the 10 mpg ranger or so; I'll know for sure once I fill on the way back to work in a couple weeks.
gus
Old 01-01-2014, 09:13 PM   #36
Chassis: Ward
Rated Cap: 1
Been working on the inside walls of the bus while at home. I've still got 3 days and hope to get a couple partitions up and get oak flooring down.
I found enough solid oak flooring from an old house to do the floor for $100.00
The 1X4" used tougue and groove flooring on the walls came from my next door neighbor and friend. He's been cheering me on every morning over coffee since I've been home.
My wife was extremely sick over the Christmas holiday so needed some tending to. I lost a couple days work over that.
Following are a few pics. of the inside with the tounge & groove on the walls.
gus
Old 01-03-2014, 02:52 PM   #37
Old 01-03-2014, 03:20 PM   #38
JakeC's Avatar
That is some awesome progress!! Love it! Sounds like you are scoring some really good deals, too.
Brutus
Old 01-03-2014, 07:00 PM   #39
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
The wood on the walls looks great.
Old 01-12-2014, 09:57 PM   #40
Starting to look like home in there!!! Looks great, and oak..... so nice!
Charon's transformation has finally begun. Stuff Skoolie Conversion Projects 3 04-11-2010 10:35 PM
First Project salee05 Skoolie Conversion Projects 0 09-02-2009 10:25 PM
Trade 1970 VW Karmann Ghia project for skoolie project bus? shortwaverunner Classifieds | Buy, Sell, Swap 3 02-03-2006 09:56 AM
Project Bio Bus Steve Skoolie Conversion Projects 1 09-28-2004 09:04 AM
new project too bigdan Skoolie Conversion Projects 7 08-01-2004 07:49 AM
