Old 03-23-2014, 10:30 PM   #61
Chassis: Ward
Engine: 6.6L Brazilian Ford
Rated Cap: 1
Re: Project Transformation
One wheel well is in the closet and the other will be under a settee and under the cupboard. I had the whole underneath side of the bus sprayed with Styrofoam insulation but I will insulate a little over the wheel wells before I cover them. There is like 2-2 1/2 inches outside the wheel wells. It doesn't seem to bottom out on the wheels either.
Originally Posted by scgwagner
I really like your flooring. Will you insulate and/or build box structures over your wheel wells?
Bus Transformation: My CHEAP project >>> viewtopic.php?f=9&t=466640
gus
gusbus is offline   Reply With Quote
Old 03-24-2014, 06:44 PM   #62
Chassis: AmTran
Gotcha. That sounds like a very wise use of space, placing your cupboard, closet and settee over them! Can't wait to finally get our bus and do the real layout with it's measurements! I am looking forward to your continued build!!
Conversion Thread:
viewtopic.php?f=9&t=467377
scgwagner is offline   Reply With Quote
Charon's transformation has finally begun. Stuff Skoolie Conversion Projects 3 04-11-2010 10:35 PM
First Project salee05 Skoolie Conversion Projects 0 09-02-2009 10:25 PM
Trade 1970 VW Karmann Ghia project for skoolie project bus? shortwaverunner Classifieds | Buy, Sell, Swap 3 02-03-2006 09:56 AM
Project Bio Bus Steve Skoolie Conversion Projects 1 09-28-2004 09:04 AM
new project too bigdan Skoolie Conversion Projects 7 08-01-2004 07:49 AM
