Old 02-14-2017, 10:20 PM   #1
Coachwork: Blue-Bird
Engine: 5.9
Putting a deposit on..
1996 Blue Bird School Bus. This is a 72 passenger bus. It has 156,000 miles and has the 5.9T Cummings diesel and the Allison AT545 transmission, hydraulic breaks. New rubber all around, 2 new batteries, new starter, and seats will be removed.
Moose is offline   Reply With Quote
Old 02-14-2017, 10:25 PM   #2
oricha1984's Avatar
Engine: gasser probably
Looks good dude.
Sent from my BLU LIFE ONE X using Tapatalk
oricha1984 is offline   Reply With Quote
Old 02-15-2017, 12:25 AM   #3
Chassis: TC 2000 bluebird
Engine: 5.9 cummins
Nice! The journey begins... many sleepless nights, busted knuckles, broke budgets, sore back, rinsing crud out of your eye, scrubbing paints and adhesive off your hands, bandaging scrapes and cuts, searching craigslist for supplies and parts, trips to the lumber company, and hardware store, drilling out rivets, prying up old flooring, and yes trips to the ER. If you have a spouse: "if you had just bought an rv we could have been camping a year/years ago", and "we have spent enough money on the bus now". "Lets just finish it with what we already have".
Good luck, its quite a journey!
Bill
miltruckman is offline   Reply With Quote
Old 02-15-2017, 12:42 AM   #4
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Cool
Bill
You know my old lady? She got on bus once, begrudgingly, and promptly complained. Helped 1 time, for 5 minutes- putting air in fuel tank while I laid underneath marking diesel leaks, and griped for hour.
I wonder why men find younger women at this age.
/rant
Old 02-15-2017, 01:41 AM   #5
Hah. I think I'm lucky there. My wife already knows a) that RVs are usually built like junk, and b) that this will be a " project" more than an immediately usable piece of equipment.
lucasd is offline   Reply With Quote
Old 02-15-2017, 02:03 AM   #6
It would appear as if you have found a pretty nice bus.
The fact it has hydraulic brakes tends to make me think that is a really light duty bus. As you build your bus make sure you are keeping track of the weights of stuff you put in. On a bus like yours it would be very easy to overload the front axle. You may have less than half the weight of the GVWR for a total but if it is in the wrong places you could have some problems.
Another problem is your transmission most likely does NOT have a park position. That means when you park the only thing keeping your bus from moving is the hand/emergency brake. Which also means you need to invest in a good set of wheel chocks--not the cheesy little RV wheel chocks but the big heavy duty ones truckers use. The hand/emergency brakes on those buses are pretty whimpy and I would NOT trust my life and loved ones to it even if I was parked in a level spot.
Good luck and happy trails to you!
Old 02-15-2017, 04:54 AM   #7
Deposit?
Is it a dealer?
Roll Your Own Build Thread
Old 02-15-2017, 07:35 AM   #8
BurlKing's Avatar
Year: 92
Engine: DTA360 5.9L
100% right. was working on my bus one day and had to move it closer to a 220v outlet to plasma cut and it ended up being at a slight incline when done. I have a manual so once i shut it off i put it in a gear opposite of the incline and then set the hand brake. I always use wheel chocks too, started the bus (which means putting it into nuetral) then went out and removed the chocks meanwhile the parking brake is still set and when i removed the last chock it started to roll backwards. Ran around to the front door, pryed it open real quick and lept into the drivers seat and slammed the brakes. scary ****. wheel chocks are the best investment if you wanna keep your bus!
BurlKing is offline   Reply With Quote
Old 02-15-2017, 07:42 AM   #9
/rant
I went out and bought a school bus... and waited.. waited for that 'rant'.. - wait . silence. - yes silence.. oh wait.. theres no wife, No GF, no BF, no Husband..
so I went out and bought another school bus..
Old 02-15-2017, 07:47 AM   #10
Coachwork: BB
Engine: Cummins
Rated Cap: 25.999K
LMAO..... You're my Hero my friend!!!!
SDR76 is offline   Reply With Quote
Old 02-15-2017, 08:00 AM   #11
Engine: Navistar 7.6L
Have you seen this bus in person?
That 675 area code on the building in the background is not in the U.S.A.
DoubleO7 is offline   Reply With Quote
Old 02-15-2017, 08:14 AM   #12
James has a valid point.......
https://www.google.com/search?q=area...UTF-8&hl=en-US
But if it's 678, it's in Atlanta
https://www.google.com/search?safe=o...46.wLSWn6VQtRc
Old 02-15-2017, 08:56 AM   #13
Originally Posted by milkmania View Post
oops, your right it is 678
And the number on the building checks out to as in Gainesville, GA
https://www.facebook.com/pages/Igles...58074794496404
Old 02-15-2017, 11:02 AM   #14
Engine: 5.9
Yes it is from a small used car lot. I have seen the bus and run the bus. Today I will drive the bus before deposit. Only reason for deposit is for them to remove seats before sale and title to show picture of seats removal.
Will check park position.
All placard with GVW removed and not on old title
Old 02-15-2017, 04:05 PM   #15
I work in Gainesville near the airport. What car lot is this? I need to check them out. I'm guessing its on Atlanta Hwy. as its predominantly Hispanic.
BigDavid is offline   Reply With Quote
Old 02-15-2017, 06:24 PM   #16
Engine: 5.9
717 Atlanta Hwy
Old 02-15-2017, 07:33 PM   #17
10-4
Good luck with the bus.
Old 04-06-2017, 11:04 AM   #18
Engine: 5.9
Under Bus Storage
This is for genny, propane and shore power hook up
David Moose
