Old 11-02-2011, 03:05 PM   #51
MikeyBskunk's Avatar
Coachwork: Ford
Chassis: Carpenter
Engine: 7.8 New Holland
Re: Sherm's family's new skoolie!
250!!!!!??? wow major score!!! i guess i should check craigslist
MikeyBskunk is offline   Reply With Quote
Old 11-03-2011, 07:15 AM   #52
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
Craigslist rocks. I scan it almost daily since I'm in the 'collection' phaze ;)
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 11-04-2011, 04:00 AM   #53
BigSherm's Avatar
Engine: 8.3 Cummins turbo diesel
Qwertyuiop
Qwertyuiop
BigSherm is offline   Reply With Quote
Old 11-25-2011, 11:19 AM   #54
BigSherm's Avatar
Qwertyuiop
Qwertyuiop
Old 11-25-2011, 04:27 PM   #55
BigSherm's Avatar
Qwertyuiop
Qwertyuiop
Old 11-25-2011, 07:44 PM   #56
way to go!! give yourselfs a big pat on the back for all your work, and a new start to your life. its a good feeling knowing you built this your selfs, We had a blast on our first trip out, and the first meals etc.,
we wish all the best you and your family
safe travels, keep us posted
Old 11-25-2011, 09:15 PM   #57
lornaschinske's Avatar
Rated Cap: 89
Originally Posted by BigSherm
... After some internet research about hooking a household stove up to a standard BBQ tank, I was able to find the propane regulator I needed at an RV store (a standard BBQ propane regulator's pressure is too low)... My experience about this is: don't be discouraged by everyone that says you can't run a regular, household stove and oven from a BBQ tank. You'll get a lot of folks at hardware stores, etc, who will look at you like you're stupid when you tell them what you're doing. It works great!
How strange. We used a little LP regulator like what goes on the bigger BBQ grills (not the little combo regulator/control like you find on the portable table top grills) to run my 30" LP range. This is not the first time that we have done this. We use the same regulator we used on the pop-up and on ALL our BBQ tanks to run various LP stuff. We've done this over a couple of decades. I don't know what you read or were told, but you either misunderstood or you were told wrong.
Fulltime since 2006
Old 11-25-2011, 10:10 PM   #58
BigSherm's Avatar
Qwertyuiop
Qwertyuiop
Old 11-26-2011, 07:21 AM   #59
my dad runs a full size stove off a 20lb tank, oven works well. most stoves , fridges, bbqs, can run (did it in my bus), if you some big ass commercal stove then a bigger reg ismay be needed. one thing I do know, is the cheapee reg on my little home bbq crapped out, so when i put one in the bus, I got a better quaity then on standared bbq, I saw a adjustable reg as well it was used for big industral stuff.
anyway make a loaf of bread, and enjoy the ocean veiw you have now
Old 11-26-2011, 07:31 AM   #60
pipopak's Avatar
About the cook top: just remember that burns oxygen, so an open window is a must. Also some kind of chimney for exhaust gases. Make sure the hose does not rub anywhere. Other than that, you figured it right. Have fun!.
pipopak is offline   Reply With Quote
