09-06-2011, 05:32 PM
Engine: 8.3 Cummins turbo diesel
Qwertyuiop
Qwertyuiop
09-06-2011, 05:40 PM
Qwertyuiop
Qwertyuiop
09-06-2011, 06:39 PM
Engine: International T444E
Rated Cap: 71
Re: Sherm's family's new skoolie!
Welcome! Looking forward to seeing what you have planned.
09-06-2011, 08:25 PM
Chassis: aare 40
Engine: cummins 8.3
glad to see shes in good hands. 80 mph damn ;)
09-06-2011, 08:38 PM
Engine: DT466/AT545
Welcome! Looks like you've got a great bus with a great drivetrain and painted to boot! Nice!
09-06-2011, 09:47 PM
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Welcome! Nice bus. But man-you made me jump reading the title -since my 1st name is Sherman. Yea--its not like yelling out "hey Bob!" at the mall-quite rare to see or here it.
09-06-2011, 10:37 PM
Year: 1977
Chassis: International Harvester
The bus looks good. Can't way to see how it works out. And thanks for your time form a fellow Vet.
09-07-2011, 12:01 AM
Coachwork: Ford
Chassis: Carpenter
Engine: 7.8 New Holland
Very nice!! sounds like a fun family project that should bring the family even closer!
09-07-2011, 12:34 AM
Qwertyuiop
Qwertyuiop
09-07-2011, 01:13 AM
Plans look great, don't forget to factor in where the fender wells are though. Good luck
Living the dream in the Kootenays
09-07-2011, 07:46 AM
Engine: DT466/AT545
Looks like a good overall layout of the floorplan. You might consider switching the kitchen with the dining area so the kitchen plumbing is on the same side of the bus as the bathroom plumbing. That way also, you can more easily talk to your passengers when driving down the road if they are not directly behind you. Having plumbing on the driver's side is a good idea because that is where the external hookups are usually located at campgrounds/dump stations.
09-07-2011, 08:35 AM
Qwertyuiop
09-07-2011, 10:09 AM
not bad!!
09-07-2011, 03:09 PM
Engine: DT466/AT545
Oh, and if you think you will ever consider retrofitting a real RV toilet, you will want to locate your "composting toilet" somewhere that you could later mount a black water tank directly under it. And of course if you have a wheel located right under a drain, that may cause routing problems.
09-07-2011, 09:56 PM
Originally Posted by Iceni John
Good looking bus!
I know it's tempting to start building the interior first (most people do), but give serious thought now, before everything in place, to where your tanks/batteries/propane/etc will have to go. Their locations may end up dictating how the interior will be. How the frame rails and under-structure are on your bus is immutable, and everything else has to fit around them. And if you have bellybins, don't use them for tanks etc - keep the bellybins for storage, because you can fit larger tanks outside them under the floor instead.
Have fun, John
I have been going over my plans for like a year so far, basically is set but still every time I find a "negative improvement" that needs to be addressed. But they are becoming rarer. In the process I wrote all my notes in a rather large file. If anybody wants a copy PM me.
09-08-2011, 02:21 PM
Chassis: All-American R/E
Mind you, it will still be plenty hot back there, even with the insulation. Of course, not the case in the winter, it will be cold. I went sideways with mine. I might change it around yet. Also, I get 9mpg, I dont think we are going to get better than that.
09-08-2011, 06:11 PM
Qwertyuiop
Qwertyuiop
09-08-2011, 06:24 PM
Qwertyuiop
Qwertyuiop
09-08-2011, 10:20 PM
Chassis: aare 40
Engine: cummins 8.3
beautiful! ;) way to get it done.
09-09-2011, 10:37 AM
woot! way to work the system man. they want it, you gave it lol. Im lucky and only need 2 of the following in Sask!
