09-15-2009, 10:07 AM
Year: 1994
Coachwork: Ford
Chassis: Carpenter
Rain Barrel/Rain Water Catchment
So right now as we are in the midst of converting our school bus to a bus on wheels, we are hoping to build a rain water catchment system that collects rainwater from the roof from gutters and then using pvc pipe, empties into our rain barrel inside of the bus. We'll use the water for our rooftop garden as well as purify it for drinking and washing dishes and possibly for shower water.
Anybody have experience building a rain water catchment system for their bus? Or have any structurally-sound suggestions for attaching the gutters to the roof (especially since our bus will be ravaging the roads - at moderate speeds)?
Thanks ever so much for your help - even though we're all a bit crazy.
Bethel and the Waste-Not Wagoneers
http://wastenotwagon.wordpress.com
09-15-2009, 02:24 PM
Re: Rain Barrel/Rain Water Catchment
What about flipping the roof? You could then have some sort of screen to prevent debris from settling in there. Just thinking out loud.
You may consider having the water tank mounted high in the cavity so you could pressurize your plumbing with gravity.
09-15-2009, 04:24 PM
Year: 1969
Chassis: Chevrolet
Engine: 350 Chevrolet
With a flipped roof, you could do away with the windshield washer resivoir! Just slam on the brakes and hit the wipers!!
09-15-2009, 06:59 PM
Engine: Detroit
Why not use normal "leaf-guard" gutters like those for a house? You'll need some way to keep debris out anyway... why try to reinvent the wheel? They are meant to be installed next to the house, so you'll have all the typical attachment hardware. Just a thought.
09-15-2009, 08:45 PM
I read a conversion log of a army truck conversion in australia where they did some rain water catchment. In their case, they only used it for showers and flushing, and kept drinking/cooking water quite separate.
Seems like a really good idea, especially for those considering long term boondocking. However, don't forget to factor in cold weather in your design (in case you find yourself in the snowy north).
Ah, found the link to the guy's conversion info... http://www.robgray.com/graynomad/wot...izat/index.php.
Very interesting reading, or at least I thought so. Lots of great ideas in there.
jim
09-15-2009, 09:35 PM
I'd drink the water after running it through my Big Berkey.
09-16-2009, 10:25 AM
Year: 1969
Chassis: Chevrolet
mightybus wrote:
You're just saying that because you got your brakes fixed.
Now that there was FUNNY!...I don't care why ya are
lmao!! I got a good chuckle....
I been thinkin about the gutters and I could see using it for flushing and maybe watering plants but I think that all the the stuff to make it drinkable would be an awfully big use of space? Of course I have no idea what it would take. but maybe what about a still of some sort? boiling the water, catching the steam and cooling it off and then let the condensation drip into another container and then that would be clean wouldnt it??? Or would it still need to be purified??
09-20-2009, 09:51 AM
Look (google) at solar distillers or 'shine stills, oops...sorry ... meant fuel distillation.
"Offish, Honest-er! Ish jest a li'l ol' jar of corn water!
I would think you might want to at least run all your drinking water through the sediment and charcoal filters mentioned in ben2go's Texas manual. (Thanks, great reference!) Even if you are hooked up to campground water, you don't know where it's been. I intend to build in filtering, but on short trips to parks run by State Environmental agencies I trust the taps. After all, they set the standards that the municipal/private systems must meet.
09-20-2009, 10:41 AM
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Another way to catch rainwater would be to install a roof deck with a "solid" surface -- corrugated metal comes to mind, with the valleys running the length of the bus -- then have a gutter at the lowest point (front, back, middle?) for collection.
I've not seen one, but I've read about a system in rainwater catchment setups where the first x gallons are diverted, because that is where most of the dirt, twigs, bugs, and bird poop will be. After some number of gallons, the flow is redirected to the main catch basin.
Using a 7.5' x 30' (32,400 square inches) surface as a catchment area, an inch of rain will yield 140 gallons Pretty nice.
Minus some for inefficiencies throughout the system.
PS: Can we move this to the Conversion Discussion forum? Great topic, would hate for it to be missed.
09-30-2009, 06:59 PM
Year: 1994
Coachwork: Ford
Chassis: Carpenter
Originally Posted by Smitty
I've thought about splitting a piece of 2" PVC (lengthways) for gutter, and adding a fittig on te lower end to screw a garden hose to & run it to a 55 gal plastic barrel, either a barrel for each side, or both hoses into 1 barrel. . . .
Having a "portable" 12v pump would be handy for transfering water to a holding tank, unless you just used it on an as-needed basis. Be sure to update if you come-up with a method.
Smitty
we have just installed a pvc gutter with pvc piping into the bus. removed the last two windows on the backside of the bus to make sure there is a tight fitting. and then have pvc piping on the inside draining into a homemade rainwater barrel.
we are thinking of installing a manual handpump (as we try to toy around with alternative/appropriate technologies) that can be built by us and easily constructed with little to no money or scavenged - so thinking along those lines rather than a battery powered pump. we're planning on using the water for our garden (eventually on the rooftop) and possibly purifying it for drinking or washing dishes. or maybe for an outdoor shower (and then making a solar water heater).
hopefully we'll be posting pictures soon to show our mad farmer progress.
love, the waste-not wagoneers
09-30-2009, 07:04 PM
Year: 1994
Coachwork: Ford
Chassis: Carpenter
also - we did incorporate a flush pipe so that the first bits of water are collected in the flush pipe rather than being stored in our rainwater tank.
-the waste-not wagoneers
10-01-2009, 04:28 PM
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Sean- Curious as to why you'd add panels to the top of the roof? I mean all the rain that falls on the roof spills-over the sides anyway. And you'd just end-up with bird crap, bugs, leaves & everything else all-over the new panels sooner or later. 140 gallons for an inch of rain is a good bit of water
Just seems like it would be simpler to collect rain along a short axis of the bus rather than two long axes. But only if there is already a roof deck in the plans.
I think bird poop, dirt, leaves etc are inevitable regardless of the collection method.
11-09-2009, 11:35 PM
Year: 1994
Coachwork: Ford
Chassis: Carpenter
sorry to folks who were once interested and perhaps have lost interest in our rainwater catchment system. we have finally finished and taken photos of what our system now looks like. more information is found on our website (since i don't know how to post photos here): http://wastenotwagon.wordpress.com. in a nutshell, we used pvc pipe (cut in half) as our gutters - running along both sides of the bus. those are channeled into the bus and the water is stored in a 55-gallon barrel. we have gate valves to prevent overflow. eventually we hope to have a hand pump for extracting water. right now, it is a closed container, holding water.
thanks for your patience and interest.
the waste-not wagoneers.
11-11-2009, 11:28 AM
Coachwork: Bluebird tc2000
Chassis: 3401-3502 ???
Engine: cummins 5.9
it seems to me that house gutters at highway speeds would be a disaster.... but on my inlaws rv they have a little have a tiny drip edge that channels then shoots the water off the back and it works well...could find somthing like that
i wouldn't drink or cook with vehicle runoff but that is just me ..... have you ever been on top of a flat top rv its just nasty
but your system ghetto or otherwise is nice
12-17-2009, 08:45 AM
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
A 1 square meter solar still will process about 5 gallons of water per day. All you need is a shallow tray sealed with a glass lid. The lid is angled so that condensate runs down its surface into it's own "rain gutter" and runs off to a collection tank.
Of course, the collection amount depends on the amount of sunlight you have, but 5gpd is a reasonable expectation in temperate climes with decent sunlight.
