Well did the wall insulation over the weekend. Next time I see one of those questions pop up asking if it's necessary to remove the interior skins I'll have to chime in with me 2 cents. I didn't realize it from looking at the outside but there were drill holes on both sides of the walls. It wasn't until removed the old insulation and saw the light shining through. Any way patched them up and kept moving forward.
Yea but I really need to get that top insulation done. Without it the AC is useless. But if you ever truly wanted to know what an oven feels like convert a bus in Arizona 115 degree heat.
Not sure I thought this out very well.
Sent from my Pixel using Tapatalk
I can relate, only I have a TON of humidity to deal with!
AZ. That might be a bad idea using bat. insulation. One little pin hole in that wheel well and that bat insulation will soak up that water like a sponge. I would recommend sealing it and use some sort of spray foam insulation. Closed cell. But that's only my thought.
I wholeheartedly agree, spray foam closed cell. That fiberglass junk is just a sponge for water!!!!!!! YUCK! And think of the mold issues along with the water issues!!!!
Just my two cents worth.....
M
