Old 06-12-2017, 09:10 AM   #21
Chassis: TC 2000
Well did the wall insulation over the weekend. Next time I see one of those questions pop up asking if it's necessary to remove the interior skins I'll have to chime in with me 2 cents. I didn't realize it from looking at the outside but there were drill holes on both sides of the walls. It wasn't until removed the old insulation and saw the light shining through. Any way patched them up and kept moving forward.
Sent from my Pixel using Tapatalk
www.shawntomskoolie.com
AZtom is offline   Reply With Quote
Old 06-12-2017, 10:54 AM   #22
Robin97396's Avatar
You're gettin it. Looks good. Brings back memories.
Robin
Nobody's Business
Old 06-28-2017, 03:31 PM   #23
Chassis: TC 2000
Windows out to be scraped off and ceiling skin removed. Damn I hate rivets!
Old 06-28-2017, 05:31 PM   #24
You DO have that A/C running, don't you? (-:
1olfart is offline   Reply With Quote
Old 06-28-2017, 05:44 PM   #25
Chassis: TC 2000
Yea but I really need to get that top insulation done. Without it the AC is useless. But if you ever truly wanted to know what an oven feels like convert a bus in Arizona 115 degree heat.
Not sure I thought this out very well.
Old 06-28-2017, 05:52 PM   #26
I can relate, only I have a TON of humidity to deal with!
Old 08-04-2017, 04:51 PM   #27
Chassis: TC 2000
Got some good progress done.
Insulation... Check
Side walls..... Check
Windows sills... In progress
Window frames... In progress
Old 08-05-2017, 08:27 PM   #28
tobeamiss's Avatar
That's looking great. What is that small wood you used under the window... it looks rounded.
Sent from my SM-T350 using Tapatalk
oh yes she did!
https://www.skoolie.net/forums/f11/to...-it-16557.html
Old 08-05-2017, 09:19 PM   #29
Chassis: TC 2000
Thx, it is rounded. I didn't like how the plywood edge looked so I found some small pine moulding.
http://www.homedepot.com/p/Woodgrain...0711/206000895
Old 08-07-2017, 07:46 PM   #30
tobeamiss's Avatar
Great idea using screen molding. Thanks for the link
oh yes she did!
Old 08-07-2017, 11:40 PM   #31
Skipoffools's Avatar
Coachwork: Carpenter (Cavalier)
Chassis: International Harvester
Engine: DTA360
Rated Cap: 63
Looking good! :
Rare but we are having 110+ degrees here in southern Oregon. I didn't know I could sweat so much.
Skipoffools is offline   Reply With Quote
Old 08-21-2017, 07:18 PM   #32
Chassis: TC 2000
Boxed in and insulated the wheel wells. Used the old insulation from the ceiling on this
Old 08-21-2017, 07:36 PM   #33
AZ. That might be a bad idea using bat. insulation. One little pin hole in that wheel well and that bat insulation will soak up that water like a sponge. I would recommend sealing it and use some sort of spray foam insulation. Closed cell. But that's only my thought.
captcarl is offline   Reply With Quote
Old 08-21-2017, 08:07 PM   #34
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
I wholeheartedly agree, spray foam closed cell. That fiberglass junk is just a sponge for water!!!!!!! YUCK! And think of the mold issues along with the water issues!!!!
Just my two cents worth.....
M
M1031A1 is offline   Reply With Quote
Old 08-21-2017, 11:20 PM   #35
Chassis: TC 2000
Yea good point. I might have to unscrew the top and remove the fiberglass before I get to far ahead
Old 08-22-2017, 05:12 AM   #36
tobeamiss's Avatar
I'm in love with closed cell spray foam. I sprayed some up under my wheel wells as insurance to keep things dry because I had to do a patch job.
oh yes she did!
Old 08-22-2017, 07:19 PM   #37
AZ. Great job on your conversion. I'm learning a lot from this forum.
Old 08-22-2017, 08:10 PM   #38
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
My Bluebird was spray foamed from the factory- including under the wheel-wells.
Old 08-23-2017, 07:17 AM   #39
tobeamiss's Avatar
That's neat. They should all come like that. I was a real newbie when I did it and wondered if it was the right thing to do...[emoji590] [emoji2]
oh yes she did!
Old 08-24-2017, 12:48 AM   #40
zoomy's Avatar
Chassis: Thomas Saf T Line
Engine: 8.3L Cummins
where in AZ are you?
and i agree spray foam is the way to go. i used foam it green. hopefully ill be putting up a video of it soon.
zoomy is offline   Reply With Quote
