Old 05-10-2006, 09:29 PM   #11
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Here's a couple shots of another ramp configuration:
http://www.husbussen.se/images/start/mix/qld225_02.jpg
http://www.husbussen.se/images/start/mix/qld225_01.jpg
Griff is offline   Reply With Quote
Old 12-23-2017, 10:24 PM   #12
None of the previous links are live. Can anyone direct me to options for converting to a wider rear door for motorcycle storage. I'm wanting to do a short 6-7' shop at the back with a hard wall and door up to the RV section.
Old 12-23-2017, 11:10 PM   #13
Robin97396's Avatar
I've seen that done once to accommodate inflatable river rafts.
Are you sure a wheel chair lift wouldn't work well for that. My garage is in the rear 6' of the bus and the chair lift insures I don't have unhappy attempts at getting the bike through the back door.
Anyway to answer your question the widened rear entry that I saw was done by cutting out the driver's side portion of the rear wall, including the window. That section of wall was hinged so it could swing open opposite of the original rear door making about a six foot wide entry. From what I understand the biggest problem was they had trouble sealing airflow on that rear wall section.
Robin
Nobody's Business
Old 12-23-2017, 11:28 PM   #14
I just had a thought, cut off the back 6" of a front wrecked van and weld the door assembly to the rear of the bus. Takes care of the wind sealing issue. Wheel lift might work, but would need to accommodate 5' wheelbase and would add a bunch of weight.
Do you use the rear door of your bus? stonestatue Conversion General Discussions 12 10-01-2012 11:50 PM
Side door/ Rear door SeanF Conversion General Discussions 6 05-24-2009 11:56 AM
Rear door BusDude Classifieds | Buy, Sell, Swap 0 11-01-2006 02:40 PM
Rear door lock Kirbystud Conversion General Discussions 22 08-16-2005 03:47 AM
Rear storage / Rear door ideas allanwcoty Conversion General Discussions 0 05-17-2005 11:52 AM
