Old 04-09-2016, 04:28 PM   #131
Robin97396's Avatar
Chassis: TC 1000
Engine: 5.9
Send a message via Yahoo to Robin97396
Yes we all try to drive prudently, but sometimes unexpected things happen.
Robin97396 is online now   Reply With Quote
Old 04-09-2016, 09:31 PM   #132
I agree with HPD and am not too worried about securing the floor. In the event of a roll over all bets are off! There is no telling what will break loose and which way it will go flying even with a secure floor. My bus build only exists in my head but it does have a floating floor and if I wanted to secure it in the event of a roll over it would not be difficult I don't think.
My build thought was to run 2X4's or 2x2's horizontally the length of the bus on the walls and the roof spacing them around two feet apart. They would be attached on the outside of the buses ribs that way i would have a little less then 2 inches of extra insulation beyond the buses ribs. My floating floor would be framed with 2X4's and have 2X4's running down the center isle for cabinets and walls to be secured to (With a few slight variation to accommodate my floor plan of course). The simplest way to secure the floor in the event of a roll over would be to run 2X2's or 2X4's vertically between the bottom wall horizontal down to the floor.
Every build is different but I'm sure anyone who wants the extra safety of securing the floor could do something similar.
Kipin is offline   Reply With Quote
Old 04-09-2016, 10:53 PM   #133
Robin97396's Avatar
Chassis: TC 1000
Engine: 5.9
I'd say these buses are pretty safe, and yeah in the case of a roll over a little loose flooring would be pretty light compared to the fridge. With a few walls on top of your floor I don't think it's floating anymore.
Not to worry, it sounds like you're plenty safe.
Old 04-10-2016, 06:20 AM   #134
jester's Avatar
Chassis: RE200
Engine: 7.3L Navistar T444E
i run floating floor as well. i used reflectix as padding for added R factor. Once all your interior framing is done the floor is no longer floating, it is secured all over the place from floor to ceiling framing. no way for floor to fly around. and all appliances should be secured with strapping while rolling anyway. I will be installing boat tie off cleats to use for our fridge while we moving.
check out my build pics
http://www.skoolie.net/forums/member...albums833.html
or my random writings... at
www.roadrunnerlogik.blogspot.com
jester is offline   Reply With Quote
Old 04-10-2016, 08:39 AM   #135
Engine: Cat 3126e
Rated Cap: 28
Originally Posted by ArmyChap View Post
Gym flooring is going to look fantastic in your bus! Very creative idea... I can't wait to see how it turns out!
It should look pretty sweet, will def keep you updated.
Originally Posted by FlyboyHPD View Post
The floating floor concept is really the way to go. Securing anything to it should not be a problem if you put down 1/2" or 3/4" plywood down over your solid foam insulation.
I couldn't agree more! I used 3/4" and have the (studs) sleepers on the sides and some in the middle to screw down onto as well.
In a vehicle that can roll over everything needs to be fastened down IMO. Even things you think are fastened down securely can break loose.
The floor its self won't be able to come out due to the chair rail being right above it. It could potentionaly only move about 6"ish if everything did break off.
However, if you happen to be in a bad enough situation to roll the bus your chances of living through it have decreased significantly anyway. x2
I'm going with the floating floor in mine and taking my chances by driving very prudently and remembering I'm in charge of 36,000 rolling pounds within my ability to control. Therefore going 60 mph is plenty fast for me as I'll be in no hurry to get anywhere. x2
there is no reason why items up against the walls cannot be bolted to the walls and secured that way.
Ya I think that securing to the wall and floor in multiple spots along with being mindful when driving there will be no issues. Freak accidents do happen but other than that its in your control, just like you said.
That's a great idea! I have been looking at a few things, but that is perfect!
Josiahdr is offline   Reply With Quote
Old 04-10-2016, 09:52 AM   #136
While on the subject of floor strategies...
I have been considering using tool box type rubber mesh beneath my plywood (no room for insulation, trust me). It is open, breathes, is mold and fungus proof (according to the mfg'r) and should provide a bit of thermal break as well as some sound insulation.
Can anyone think of a reason not to go this route?
Old 04-10-2016, 10:01 AM   #137
Engine: Cat 3126e
Rated Cap: 28
Not at all. Should work well.
Old 04-10-2016, 10:38 AM   #138
FlyboyHPD's Avatar
Chassis: AmTran
Sounds like a good plan Tango .
1999 International AmTran, DT466E, MD3060
https://flyboyrv.wordpress.com/
FlyboyHPD is offline   Reply With Quote
Old 04-10-2016, 12:05 PM   #139
Chassis: International S3800
I would float the floor on top of the rubber tool-box coating and then make sure anything else is strapped to the WALL SUPPORTS.. if you flip the bus anything strapped to a secured floor is likely to break loose anyway as the frame rails flex.. if you run Bolts and BIG washers.. up through the bottom of your floating floor before you install it and then mount your cabinets / sppliances, etc to your floating floor and to the walls, you have a fighting chance that things will flex together and not break completely onto their own..
ie the floor stays together even though it may bow and pull away from the main bus floor when the frame twists.. things will come away from the walls too however not as likely to break completely free as they flex with the detached floor as a unit...
not everything will come apart in a crash.. the most likely crash ends up with your bus on its side... ..
I learned recently of 2 acquaintences of mine that were run off I-95 in florida by a Semi driver who dozed off.. their commercial RV(some kind of LARGE fleetwood) went in the median and landed on its side.. they werent hurt and only one cabinet inside even opened up...(all of their cabinets had aviation style safety latches.. lots of things twisted and windows broke but no large objects went flying.. the RV looked pretty twisted.. I didnt see much of the inside so I dont know how it was constructed.. but the fact is you can build your Bus to stay together even in a pretty severe crash...
im of the mind that things allowed to flex are less likely to Break loose.. and on a more normal thought.. less likely to vibrate or rattle..
Old 04-22-2016, 10:39 PM   #140
Engine: Cat 3126e
Rated Cap: 28
Just an update as far as the bus being dead. Getting it towed to a shop to get back up and running. Got a good deal for the tow though.
