Old 05-15-2016, 11:44 AM   #161
Engine: Cat 3126e
Rated Cap: 28
Video update on the spray foam install and covering up the emergency exit. Pt2 will be following shortly.
Josiahdr is offline   Reply With Quote
Old 05-15-2016, 09:41 PM   #162
Engine: Cat 3126e
Rated Cap: 28
Old 05-15-2016, 11:53 PM   #163
May I ask where you purchased your spray foam from? That looks like the perfect option for me as well.
Sent from my SAMSUNG-SM-N900A using Tapatalk
jbohall001 is offline   Reply With Quote
Old 05-16-2016, 12:27 AM   #164
Engine: Cat 3126e
Rated Cap: 28
http://tigerfoam.com/sprayfoaminsula...oard-foot-kit/
Directly from them, I also found a $5 off coupon online. The shipping was $130 but it turned out to be $50 bucks less than amazon.
Old 05-16-2016, 12:32 AM   #165
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Originally Posted by Josiahdr View Post
Tiger Foam | Spray Foam Insulation Kit | TF-600FR
After setting, how thick is it?
What was the total cost?
Roll Your Own Build Thread
Old 05-16-2016, 12:56 AM   #166
Engine: Cat 3126e
Rated Cap: 28
$700 Well I focused more so below the window and that is full so about 2". The ceiling I wasn't to concerned about and have an 1" same with the front bulk head. The rear bulk head other than the lower panel that will have foam board, has around 3" on the bulkhead and 2"-2.5" on the ceiling and walls around the rear.
Reason for doing so heat rises and cold air sink I want to be efficient when running the AC. Also we will sleep in the back so hopefully that will help. I am debating on if I will put up reflectix on the ceiling but definitely will be putting in some insulation in the front bulk head to help with noise.
I also went back around the next day and used 10 cans of great stuff to touch up some spots. So technically $740
Old 05-18-2016, 09:50 PM   #167
Engine: Cat 3126e
Rated Cap: 28
Got the ceiling started today. Red Oak.
Old 05-18-2016, 10:01 PM   #168
Chassis: International S3800
Wow! That red oak is going to look really nice! Are you sealing between the boards or letting the insulation handle that ?
Should make for a warm ceiling in winter and block a lot of heat in summer
Christopher
Old 05-18-2016, 10:06 PM   #169
Engine: Cat 3126e
Rated Cap: 28
Christopher
Thank you!! No we are folding up reflectix and puting it between the foam and flooring.
I was going to add silicone to the board and rib but it seems quite solid. Going to give it a little test run up and down the street before more goes in. Just to test it to determine.
Old 05-18-2016, 10:50 PM   #170
Robin97396's Avatar
Chassis: TC 1000
Engine: 5.9
Rated Cap: Three
Looking good on that insulation and love that red oak. Did you get one of the 1000sf foam packages to spray it that deep?
