Old 05-21-2016, 12:47 PM   #181
Robin97396's Avatar
I like the look of that wood you're putting up so much that I'm going to do something very similar. That makes it look so much more like a home. You guys work good together.
I haven't actually answered the question of doing just the rear sleeping area or as much of the floor as possible. I'd say that largely depends on how much of the underside I'm able to effectively spray without other things being in the way. For larger flat areas maybe I could affix chicken wire to the bottom of the floor in between the floor joist. It's very rust resistant and would act like tiny re-bar in the foam. It sounds like a PITA to affix something for the foam to cling to, but I think the spray foam may have a tendency to eventually delaminate from the underside of the floor due to vibration and moisture. Even chicken wire stuck up on the bottom of the floor would be better than just depending on the foam sticking to the underside by itself.
So I'm still undecided about doing the whole floor or not. I have pretty well convinced myself that I'll need the 1000 bf package of foam. I like to err on the side of excess, rather than not having quite enough to do the job. Besides, I had cold feet last winter.
I think bed liner would be a good sound reducer on the underside of any bus. It's well known to have sound deadening effects, not to mention the rust prevention. After I've applied my foam and it's cured well I intend to do a test with bed liner on the foam surface with the idea of helping to reduce water absorption. That's if there's no chemical reaction between the solvent in the bed liner and the cured foam. Yeah I know it's purposed as closed cell insulation, but it does seem to sometimes hold water. Maybe that's just old foam. IDK. It's just not possible to take every precaution. If this last for 20 years it will have paid for itself many times.
Old 05-26-2016, 11:59 AM   #182
Engine: Cat 3126e
Rated Cap: 28
Got a huge section of the ceiling in yesterday!! Going back out in a few to conquer the rest. Will have some updates on our instagram
Josiahdr is offline   Reply With Quote
Old 05-26-2016, 12:04 PM   #183
Very nice! Looks great!
Sent from my SAMSUNG-SM-N900A using Tapatalk
jbohall001 is offline   Reply With Quote
Old 05-27-2016, 07:21 AM   #184
Engine: Cat 3126e
Rated Cap: 28
Old 05-27-2016, 07:27 AM   #185
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Really nice, man. Looks great!
Roll Your Own Build Thread
Old 05-27-2016, 07:45 AM   #186
Engine: Cat 3126e
Rated Cap: 28
Here is the second installment of the ceiling. Turned out better than I thought it would.
Old 05-27-2016, 09:38 AM   #187
Chassis: international
Rated Cap: 71
Looking good. You guys are moving right along.
livinthelife is offline   Reply With Quote
Old 05-27-2016, 10:09 AM   #188
Engine: Cat 3126e
Rated Cap: 28
Thanks, ya we are going to be "moving in" and back to my parents next week. Split between the bus and a spare room lol.
The build will be picking up a lot more steam now. Will be nice not to have to make a trip out to the bus and instead have it right outside.
Old 05-29-2016, 08:12 AM   #189
Engine: Cat 3126e
Rated Cap: 28
Got another video up from the ceiling install this past week. Got into a bit of an argument aswell lol.
Old 06-03-2016, 05:07 PM   #190
Man that wrangler in the back looks familiar....WF....lol
The bus is looking good!
Underground_Bear is offline   Reply With Quote
