Originally Posted by DT Rutledge
Framing members layed flat on a floor are called sleepers. Studs are vertical framing member in a wall.
Nice job by the way. I plan on much the same process in my floor.
&Thanks for watching. Oh that makes sense. Ya I have 0 knowledge of construction terms lol. Cool can't wait to see how you do yours.
Originally Posted by livinthelife
Very nice. You guys are doing great. I wish my build would go as fast as your videos on fast forward lol. Question for you. On your windows did that chemical work good that you used to clean out the old seal? I'm at that stage now. My windows have a foam strip on upper part of window and sealer on the bottom and if lucky only one side of window got sealer. Oh and how many tubes of sealer did you go through?
Thanks and love the videos!
Thank you! Glad you like the videos
HAHA I wish it actually went that fast in real life as well.
Yes the acetone worked great for cleaning the residue. I plan to use it to clean the adhesive left from the reflector stickers as well.
I used about 5-6 tubes of the sealer. I went a little over board on it just to be on the safe side. No water has leaked through at all. But I would say one tube last about 1.5-2 windows.
Did a live stream from the bus earlier.
