05-06-2016, 09:56 PM
#141
Engine: Cat 3126e
Rated Cap: 28
New Neighbor! Azuleslight
05-06-2016, 10:19 PM
#142
Chassis: international
Rated Cap: 71
Originally Posted by Josiahdr
Way cool!!! Glad to see it running again. Sucks on the amount but what can you do.
05-07-2016, 06:28 AM
#143
Always cool when you have a bus as a neighbor.
05-07-2016, 06:38 AM
#144
that rocks!! what ended up being wrong with your bus?
definitely nice having another skoolie near by!
05-07-2016, 09:11 AM
#145
Engine: Cat 3126e
Rated Cap: 28
Nothing unfortunately But saved me from having to mess with it at least.
Sure is! Def nice being able to bounce ideas back and forth.
Well... when I was removing some of the non functional wires I inadvertently clipped a ground or neutral wire that was tied into the ignition. After they spent some time on it they still needed more to diagnose it. So I just had them bypass it entirely. Now it fires right up with out a hitch.
05-07-2016, 09:58 AM
#146
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Did they know you were converting it to a skoolie? They could have just grounded the wire in the first place.
05-07-2016, 10:03 AM
#147
You know what they say, "If it aint broke, don't fix it."
Sorry to hear about the trouble and expense. That's a lot of stress.
05-08-2016, 12:05 PM
#148
Engine: Cat 3126e
Rated Cap: 28
Ya they did know and thought it was pretty cool.
There were a couple that were the problem but even after grounding them I couldn't get it to work. I should have followed the saying below. But was trying to be proactive and clean up the mess.
Thanks, ya it was a little stressful but we are back in business now.
05-08-2016, 11:12 PM
#149
Engine: Cat 3126e
Rated Cap: 28
Got the fantastic fan installed the other day. Should be able to create some nice air flow.
05-09-2016, 06:40 AM
#150
Awesome!
Just in time for summer.
05-09-2016, 10:22 AM
#151
I'm curious why you didn't use the existing hole from the emergency roof hatch instead of cutting a new hole in the roof for installing the fan?
Either way it's looking great. Glad to see you got it up and running again. Rock On !!
05-09-2016, 02:44 PM
#152
Engine: Cat 3126e
Rated Cap: 28
Awesome!
Yep!! =)
Thank You. The front emergency hatch has been extended to 2'x3' for a sky light.
05-09-2016, 05:26 PM
#153
Awesome, that makes sense. I'll be doing the same over my shower area to allow me to stand up straight.
05-09-2016, 06:14 PM
#154
Hope you have a "plug" for that puppy. Saw a rig with two about that size and the owners soon discovered how much heat came through them (they were in New Mexico). They made foam fillers to fit up into the openings on hot days. Just a thought.
05-09-2016, 06:29 PM
#155
Yeah, the filler panels are easily made or sourced from ebay. problem solved.
I've got two motorized Fantastics and one static. They're pretty nice units.
05-10-2016, 10:22 AM
#156
Engine: Cat 3126e
Rated Cap: 28
05-13-2016, 12:23 PM
#157
Engine: Cat 3126e
Rated Cap: 28
Ya may end up having some foam to put in there but will all depend once we actually start living in it. Sure do love the ambient light it provides though.
05-13-2016, 02:58 PM
#158
if it were me I'd let the light abound in and just crank up the air-conditioner when it gets too hot!..
I have a car with a plastic fixed webasto roof.. and I never close the little slider thing. . it gets warm but crank up the air and no issues..
05-13-2016, 03:04 PM
#159
Thats good for summer. In the winter, its best to stick some foam up there. Or head to FL.
05-13-2016, 04:02 PM
#160
Engine: Cat 3126e
Rated Cap: 28
Ya the AC is going to be amazing, hopefully the spray foam I put in the other day will help out as well. Hoping for it to feel like a walk in cooler lol.
Yup head to FL or or the SW. No more -10 or more for us.
