05-21-2016, 12:47 PM
#181
I like the look of that wood you're putting up so much that I'm going to do something very similar. That makes it look so much more like a home. You guys work good together.
I haven't actually answered the question of doing just the rear sleeping area or as much of the floor as possible. I'd say that largely depends on how much of the underside I'm able to effectively spray without other things being in the way. For larger flat areas maybe I could affix chicken wire to the bottom of the floor in between the floor joist. It's very rust resistant and would act like tiny re-bar in the foam. It sounds like a PITA to affix something for the foam to cling to, but I think the spray foam may have a tendency to eventually delaminate from the underside of the floor due to vibration and moisture. Even chicken wire stuck up on the bottom of the floor would be better than just depending on the foam sticking to the underside by itself.
So I'm still undecided about doing the whole floor or not. I have pretty well convinced myself that I'll need the 1000 bf package of foam. I like to err on the side of excess, rather than not having quite enough to do the job. Besides, I had cold feet last winter.
I think bed liner would be a good sound reducer on the underside of any bus. It's well known to have sound deadening effects, not to mention the rust prevention. After I've applied my foam and it's cured well I intend to do a test with bed liner on the foam surface with the idea of helping to reduce water absorption. That's if there's no chemical reaction between the solvent in the bed liner and the cured foam. Yeah I know it's purposed as closed cell insulation, but it does seem to sometimes hold water. Maybe that's just old foam. IDK. It's just not possible to take every precaution. If this last for 20 years it will have paid for itself many times.
05-26-2016, 11:59 AM
#182
Engine: Cat 3126e
Rated Cap: 28
Got a huge section of the ceiling in yesterday!! Going back out in a few to conquer the rest. Will have some updates on our instagram
05-26-2016, 12:04 PM
#183
Very nice! Looks great!
Sent from my SAMSUNG-SM-N900A using Tapatalk
05-27-2016, 07:21 AM
#184
Engine: Cat 3126e
Rated Cap: 28
05-27-2016, 07:27 AM
#185
Really nice, man. Looks great!
05-27-2016, 07:45 AM
#186
Engine: Cat 3126e
Rated Cap: 28
Here is the second installment of the ceiling. Turned out better than I thought it would.
05-27-2016, 09:38 AM
#187
Chassis: international
Rated Cap: 71
Looking good. You guys are moving right along.
05-27-2016, 10:09 AM
#188
Engine: Cat 3126e
Rated Cap: 28
Thanks, ya we are going to be "moving in" and back to my parents next week. Split between the bus and a spare room lol.
The build will be picking up a lot more steam now. Will be nice not to have to make a trip out to the bus and instead have it right outside.
05-29-2016, 08:12 AM
#189
Engine: Cat 3126e
Rated Cap: 28
Got another video up from the ceiling install this past week. Got into a bit of an argument aswell lol.
06-03-2016, 05:07 PM
#190
Man that wrangler in the back looks familiar....WF....lol
The bus is looking good!
06-03-2016, 07:29 PM
#191
Engine: Cat 3126e
Rated Cap: 28
Thanks and yep that's the project for another day lol.
06-12-2016, 11:40 AM
#192
Engine: Cat 3126e
Rated Cap: 28
Well the bus has been moved up to my parents for the rest of the conversion. Lots of changes are taking place right now but the voyage up there went smooth and with out a hitch. Also got the bus weighed and we are at 17,975 lbs currently.
Did a live video the other day will have more this week.
06-12-2016, 12:28 PM
#193
Nice, that's almost exactly what my bus weighs.
06-14-2016, 08:38 PM
#194
Engine: Cat 3126e
Rated Cap: 28
Haha, how strange lol.
Going to be cranking out some video's this week. Finally got he ceiling completed.
06-17-2016, 02:10 PM
#195
Engine: Cat 3126e
Rated Cap: 28
Starting to work on the bed area in the back. Hardest part has been trying figure out the exact way we both want it.
06-17-2016, 11:20 PM
#196
Engine: Cat 3126e
Rated Cap: 28
I was out there for most of the day and got this completed.
Also got this video completed from today. I am definitely not a carpenter by any means but it works.
06-18-2016, 02:05 PM
#197
Engine: Cat 3126e
Rated Cap: 28
Last video of bed platform storage area.
06-18-2016, 02:20 PM
#198
Chassis: Saf-T-Liner MVP ER
Engine: Cummins 5.9L Diesel Engine
Rated Cap: 83
I really like the idea of the three separate panels for storage instead of just one long one.
06-18-2016, 03:37 PM
#199
Engine: Cat 3126e
Rated Cap: 28
Thanks, ya hopefully it will be easier to get to all of the items. Breanna is going to be getting some different baskets and containers to keep everything in. Also going to leave it open underneath in case we need to store anything that is long we will still have the full length.
06-20-2016, 10:32 PM
#200
Engine: Cat 3126e
Rated Cap: 28
Did some staining today, Also painted in between the windows and started putting some trim up. But that will be in another video.
