Old 07-24-2012, 11:43 AM   #11
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Re: rivets vs self tapping screws
I used about 1500 of these
http://www.bylerrivet.com/products/i...ls.aspx?pid=42
and so far a couple hundred of these
http://www.bylerrivet.com/products/i...ls.aspx?pid=39
They are made so the nail breaks off even with the top of the rivet making them waterproof. I installed them with Harbor Freight air
rivet guns (note the 1/4 inch rivet takes the larger gun}
Byler doesn't have on line ordering, but are great people to deal with on the phone, any questions, give them a call.
Old 07-24-2012, 12:15 PM   #12
Send a message via ICQ to mightybus
On my 1988 Wayne Lifestar, the entire inside panel system is fastened with screws. No less than a Gazillion. When riveting, I prefer solid rivets if you're not in a blind area. I just use my air chisel with a chisel cut flush that I drilled a nest into that approximates the size of the rivet head. Steel rivets are always better on steel but you can use aluminum in a pinch. Ebay is the absolute best source to buy rivets at the best price, and delivered right to your front door.
mightybus is offline   Reply With Quote
Old 07-24-2012, 07:49 PM   #13
lapeer20m's Avatar
I have had several buses. Probably half of my buses had the interior panels held in place with screws. I usually remove about 8-12 feet of roof, then put it back together again.
I have used both screws and rivets with good success.
+1 for rolling a sealant onto the roof after calking and re-assembling everything.
Old 07-25-2012, 04:16 PM   #14
Please review the rivet gun,I am curious how many rivets it will do before wearing out the jaws
Old 07-25-2012, 06:04 PM   #15
Chassis: AARE
I've done about 1500 with mine, still works fine.
Old 07-25-2012, 06:26 PM   #16
Great info! thanks
Screws Instead of Rivets? rex_1_mn Conversion General Discussions 3 12-22-2012 10:23 AM
Tapping into air supply martian Conversion General Discussions 5 08-26-2010 10:06 AM
Screws for floor BUSBOZO Conversion General Discussions 11 12-13-2009 01:44 PM
Window Screws TheHokieHoopty Conversion General Discussions 3 10-25-2005 02:31 PM
Getting big screws and nasty screws out AARRGGHH!! Branden Conversion General Discussions 7 06-19-2005 08:27 PM
