Old 07-23-2012, 04:16 PM   #1
Re: rivets vs self tapping screws
using the large size rivets and also with an air riveter is what most people do, along with steel like 18 ga, heat a bit as it goes on.
Old 07-23-2012, 06:05 PM   #2
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Ever see an airplane screwed together?
Old 07-23-2012, 08:19 PM   #3
pipopak's Avatar
I have seen screwed airplanes, and a couple screwed together. But not assembled with screws....
pipopak is offline   Reply With Quote
Old 07-23-2012, 09:01 PM   #4
lornaschinske's Avatar
Rated Cap: 89
Originally Posted by richlindquist
I have about a half dozen rivets that have had the heads snap off. They are in various places around the bus, but are all on the very edge of the roof just above/in the rain gutter. What is the recommendation for repairing or just sealing them? I've tried running a screw into the holes but it runs into the rivet body.
Rich
Drill them out and rerivet with a slightly larger rivet. Is "rerivet" a word? I did my roof coating to the tops of my windows and covered all our roof rivets. Some were loose and I gooped elastometric caulk under the rivets, pushed them back in place (some required a tap from the hammer), smoothed caulk, let dry, re caulked & smoothed, let dry. Rolled Solarflex over it all.
Fulltime since 2006
Old 07-24-2012, 10:05 AM   #5
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
I used 3/16" wide flange steel pop rivets that I bought at the local Menards. They only had about 3 boxes at a time (about $2 for 25 rivets), so you may need to order them online if you go that route.
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 07-24-2012, 10:37 AM   #6
only use the steel rivets, and at least 3/16 in size.
Old 07-24-2012, 10:50 AM   #7
While it looks like you are leaning towards rivits, it should be noted that the self taping screws are meant to be used to hold tin on a building. The thread pitch on them is way too steep to withstand the riggors of highway travel in a constantly flexing bus--they will simply unwind and fall out. Because the rivits are spread out on either side of the metal, they allow for some movement although they too eventually give up but only after long service.
Old 07-24-2012, 10:58 AM   #8
i really hate to disagree, but i have put self tapping screws on the exterior of busses for 25 years, and have not had any of them fall out that i know of in my previous 4 busses. I even have some on this bus - along with rivets as well. Regular sheet metal screws if the hole is driled the correct size is far better than the self tapping ones, but takes way more time...
Just my experience..
Old 07-24-2012, 11:01 AM   #9
Lisi
I just checked out the maine college page,I really dislike facebook,can you post some updates here also?
I am interested where this will go
Maybe a small build thread?
Thanks
Old 07-24-2012, 11:16 AM   #10
'49 That's what cool about this forum. We all have had different experiences and are able to share them. Hopefully the overall result will be better built and safer Skoolies. Jack
Screws Instead of Rivets? rex_1_mn Conversion General Discussions 3 12-22-2012 10:23 AM
Tapping into air supply martian Conversion General Discussions 5 08-26-2010 10:06 AM
Screws for floor BUSBOZO Conversion General Discussions 11 12-13-2009 01:44 PM
Window Screws TheHokieHoopty Conversion General Discussions 3 10-25-2005 02:31 PM
Getting big screws and nasty screws out AARRGGHH!! Branden Conversion General Discussions 7 06-19-2005 08:27 PM
