05-15-2016, 09:56 AM
#341
Don, Mary and Spooky the cat.
#342
Yep the Senator was their flagship model.
I really wanted to see that research ship be called "Boaty McBoatface". My bus reminds me of a large boat, so the name came to mind and made me smile.
05-15-2016, 10:58 AM
#343
Did you steal that from Sponge Bob Square Pants?
05-15-2016, 11:00 AM
#344
Actually I think it was Spongebus Square Bob.
05-15-2016, 11:10 AM
#345
If CB had a FE or RE brick shape, it would be Sponge Bob Square Bus.
05-15-2016, 12:02 PM
#346
id like to see someone paint a spongebob bus..
05-15-2016, 01:24 PM
#347
I think that would look like a large block of Swiss cheese, with a face. Fun to see and do but that would attract too many little kids for my tastes.
I'm going for something plane Jane that blends in the forest and doesn't attract attention while in town. No, not camo. I've got three large camo trucks, so I don't need a camo bus.
05-15-2016, 01:50 PM
#348
you saw i went the subtle route with mine.. the letterig 'DEV RANDOM' is getting put where 'SCHOOL BUS' used to be.. that happens tomorrow then the bus is mine to take home tuesday... well actually to take back to my hotel in st petersburg then start my journey.
05-15-2016, 04:02 PM
#349
That sounds fun, and expensive. You're going to need a dual sport bike to put in there as a backup and for fun.
05-15-2016, 09:04 PM
#350
Chassis: IH 3800
Engine: Navistar DT466E
Rated Cap: 72 passenger
Instigator!
"You can finally say you have enough horsepower when you leave two black streaks from corner to corner"
(Mark Donohue, famed TransAm driver)
05-15-2016, 09:23 PM
#351
Easier with a MOPED!
And this was the inspiration for my bus' name-
'Boaty McBoatface' Happens When You Ask the Internet to Name Your Ship - Fortune
05-15-2016, 09:45 PM
#352
05-15-2016, 10:17 PM
#353
05-16-2016, 07:31 AM
#354
I've finally gotten into the groove and got 9 panels done and primed yesterday! I've got six left now, and then the worst of all this will be over. I'm elated to be getting through this.
I've got two squares of 16ga being cut out to permanently patch the hatch holes in the roof monday.
I need to start acquiring rivets now. The cheap small ones are easy enough to find, but I want a very specific rivet- plain steel closed end mandrel 1/4". Gonna need a few hundred or so.
closed end
open end
McMaster Carr and MSC have all kinds of blind rivets but they only come in Stainless Steel and Aluminum.
McMaster-Carr
Blind Rivets - MSCDirect.com
05-16-2016, 09:14 AM
#355
Engine: Cat 3126e
Rated Cap: 28
Looking Good!
05-16-2016, 11:40 AM
#356
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
Oh, and since it hasn't been taken yet, I think I'm going to officially name my bus.
Bussie McBusface
WHY DIDN'T I THINK OF THAT!!!!!!!
Awesome
05-23-2016, 06:47 AM
#357
Gonna head out to the bus today and take out the driver seat and pull the engine cover doghouse thing.
My linkage is sticking and its pretty scary. There was a recall on my hand throttle and throttle linkage, apparently. The hand throttle apparently isn't aligned properly causing wear and binding, or something.
Will probably have some questions for yall and some pics.
05-23-2016, 12:25 PM
#358
05-23-2016, 12:33 PM
#359
Gonna basically build a new one of these out of wood or metal-
bless this mess
linkage on the left
I lubed it all up LIBERALLY and worked it back and forth after I couldn't find anything broken or too worn to be causing the stickiness. After working with it and taking off different sections of the linkage I finally think I found the sticky part. The very bottom linkage- it probably got cleaned of its lube when I power washed the underside of the bus last year.
After getting everything lubed and worked its functioning great!
05-23-2016, 12:40 PM
#360
