02-07-2017, 07:00 AM
#561
Engine: Navistar 7.6L
If your going to use broke C-channel over the old ribs, why not have them make broke hat channel ?
Then you have in one piece what your creating via the C-channel and then welding on angle irons.
P.S. Raid
02-07-2017, 07:19 AM
#562
Originally Posted by BurlKing
thats some scary ****...is that a black widow in the picture? looks like it might be female and having babies. i had tons of spiders in mine before the remodel and wow....i can say i'd take 1000 spiders of what i had over that ONE there. id be walking on egg shells in my bus if i were you! not fun.
Yeah that was one of the black widows. We've also found a brown recluse and a poisonous orb spider in there.
Mostly when it sits for months.
we haven't had any brown widows in it yet, thankfully. once they settle somewhere they're almost impossible to get rid of. They came here from S Africa a few decades ago and are taking over. They're just like a black widow only brown with an orange hourglass.
02-07-2017, 07:21 AM
#563
P.S. Raid
The type of channel AmTran used in my 92 is some stupid proprietary size.
Plus- when the new hat would be set on the old ribs, the flanges wouldn't be flush with the old ones anyway, so the C channel makes more sense to me since the hat channel wouldn't be flush and would require filler strips anyway.
02-07-2017, 09:14 AM
#564
Bad news is, unless you get a really powerful, commercial spray meant specifically for spiders, the over the counter stuff won't do squat. They are tough buggers to kill. 'Bout the only way to kill'em with that stuff is to smash'em with the can.
The only thing I ever came across that would do them in instantly was the old formula of Brake Kleen. Would drop'em like a rock but the new "environmentally friendly" stuff does nothing.
02-07-2017, 09:27 AM
#565
I don't like chemicals in my living/work spaces.
I kill em mechanically.
Once you make your presence in an area regularly, they tend to go somewhere else. Especially after you kill several of them.
Brake cleaner still works here. So does carb cleaner, adhesive remover, or anything that's like that.
The one in the aluminum scooper in my pic was killed with Oreilly brake cleaner, IIRC.
02-07-2017, 09:32 AM
#566
ROOF RAISE UPDATE!
I got word from my stepdad at the shop. He's got me a test piece of channel! WWOOOOOOOOOOHOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!
If it fits, then I'm set.
Then its just he all-thread left to get.
Oh- and my rivets are ALREADY here!
gotta say- if ya need good rivets go to http://www.rivetsinstock.com/.
This will be a supplier I'll work with again. Top notch.
02-07-2017, 03:23 PM
#567
AWSOME!!! I hope the channel fits like a glove!!
02-07-2017, 06:08 PM
#568
It didn't, unfortunately. He got it all wrong. Trying again tomorrow.
Gona go UNDER the exiting hat channel on the ribs, instead of over. Then some 14ga angle on the sides and it will be good.
02-07-2017, 06:12 PM
#569
we have brown recluse in Ohio... they survive the cold winters...
when I got my bus from texas there were all kinds of spider webs underneath the bus... but one of the nice texas rainstorms on highway 10 took care of that problem.. they all got washed away... then i drove it to ohio where it was 3 degrees for like 4 days... nothing survived that under there...
02-07-2017, 08:55 PM
#570
Just maybe the only blessing of really cold weather...DEAD SPIDERS!
02-07-2017, 11:08 PM
#571
that should do it. It could be alot stronger that way.
02-08-2017, 09:01 AM
#572
Finally got a sample back that fits decent!
Gonna have 40 of them cut and bent today @ 33" each.
I can fill the gap from top to bottom from the bottom of the window to the top with that size and it will result in 12" of raise.
That's what I decided to go with, will be plenty for headroom and insulation.
02-08-2017, 09:54 AM
#573
Those look great. I think 12" raise is good, gives you headroom but doesn't make your bus so tall it can't fit under most bridges or get blown everywhere by the wind
Christopher
02-08-2017, 09:59 AM
#574
Looks good! How much is that going to cost you?
02-08-2017, 10:38 AM
#575
Year: 92
Engine: DTA360 5.9L
its really nice to see this finally coming together for you. its going to look professional when done.
02-08-2017, 01:21 PM
#576
nothing.
My stepdad's been working at that shop for nearly 40 years.
I grabbed some free all-thread and nuts while I was there. The biggest I could get was 3/4" but I think it will do just fine.
Now to get a keg. Maybe some Invasion Pale Ale?
02-08-2017, 03:21 PM
#577
Coachwork: Amtran Genesis
Looking good East Coast! Wish I could be there for the raise but travel from Washington state is too far at this time. Enjoying the thread though and looking forward to pictures of the process. It's about 20 degrees out with freezing rain on top of the new 5 inches of snow we got yesterday so I am just living vicariously through you lucky few who get to participate.
02-08-2017, 03:26 PM
#578
Thanks!
I'm sure there will be some chills and spills, and folks with actual cameras to document the madness.
I still feel like its gona be a miracle if we pull this off.
02-08-2017, 03:51 PM
#579
Rated Cap: Your mom +1
Your roof raise will go fine. I did mine by my lonesome for most of it. Only had help turning the nuts to actually raise it, did all prep, welding and cutting solo.
The time it took me to actually raise the roof with the allthread jacks after all prep was only about an hour and a half...
I wouldn't worry too much about it. I used 3/4" allthread to do my raise as well and it was more than sturdy enough to support the weight. Was originally planning on using 6 allthread lifting mechanisms, ended up only needing 4 and it was rock solid when lifting...
02-08-2017, 04:20 PM
#580
THANKS!!!
I definitely am not an ego-driven kinda guy so I can use all the encouragement/reassurance I can get. Once I do one, I'll probably be ready to do ten! But I'm a worryer by nature.
WHy herbal remedies work so well to de-stress me.
