Old 02-17-2017, 08:44 AM   #631
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Originally Posted by dan-fox View Post
I'll look at Ryobi. If their stuff is less than 50% more than the HF (like can I get a drill, a flashlight, a battery, and a charger for $30 vs $20) and the batteries interchange, that's a win and I could see standardizing on that. Right now I literally cannot tell which battery fits which tool and which charger. They're all the same except for some alignment tooth that's been arbitrarily moved 1mm or whatever.
Home depot has deals all the time for a set: drill, circular saw, sawzall type tool, and flashlight for 199 with a charger and 2 batteries.
I then bought a set with an impact driver and drill for 99 with 2 batteries and a charger.
And over the last year needed a hammer drill- 99 with 2 batts and a charger.
They aren't as inexpensive as HF, but all the batts work with all the tools.
And I can now buy just the tool I want with no battery for under 40
Old 02-17-2017, 09:21 AM   #632
Chassis: International S3800
I would LOVE to see a CnC welding bot in service... more I would love to be able to have access to one that could weld pieces for me and not cost as much as buying my own bot lolol...
im hung on work this AM, might try to get up there this afternoon for a visit..
Old 02-17-2017, 09:58 AM   #633
Engine: Navistar 7.6L
I just got done welding up a hitch for my bus.
Used my 1992 Millermatic 200 mig.
I did a lot of outside welding so I welded inside a make shift tent do to a breeze.
DoubleO7 is offline   Reply With Quote
Old 02-17-2017, 10:40 AM   #634
I LOVE both my Millermatics! (a 140 & a 210)
Old 02-17-2017, 12:06 PM   #635
Coachwork: IC
Chassis: CE300
Rated Cap: 32
IF I ever had to buy another welder I'd be going for a Miller.
They ARE the best.
But my lil Hobart should be plenty good for what I bought it for.
Roll Your Own Build Thread
Old 02-17-2017, 12:08 PM   #636
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Robots are really only for higher volume, repetitious work. LONG welds. We had one that did a weld on the outer lip of some giant augers. It would weld for an hour or two straight! I basically just kept them running, inspected the welds, and patched any areas the robots botched a bit. Mostly just watched for porosity.
THe heat they put off is astounding. You'd melt, man!
Old 02-17-2017, 12:33 PM   #637
I can only imagine the heat with a big rig like that.. I just thinking about the heat fromn a little arc of a household style 110 volt mains welder let alone that.. its all radiant heat.. straight to heat absorbing objects / people.. plus the heat that ends up in the metal after its welded... itd Nice for warmin up the warehouse in the winter up north! even with the ventilation in use. not so nice for central florida in July
Old 02-17-2017, 12:44 PM   #638
Coachwork: IC
Chassis: CE300
Rated Cap: 32
In FL no one cares about safety, either, so the exhaust fumes weren't vented. They just sorta poured out everywhere.
The air quality is why I no longer work there.
They run robots and plasmas with NO exhausts. The ones that do have exhausts are fake, and they bypass the filters and loop it right out into the shop.
They even dump the plasma dust that collects in the bins right out by the parking lot, near a marsh. Plasma dust is TERRIBLE for you. Its even got hexavalent chromium 6 in it!
FL is NOT a good place to work in manufacturing.
Old 02-17-2017, 12:47 PM   #639
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Bout to head out n see bout raising this roof in the next 24-36 hours.
Chris, if you wanna come out any time you're more than welcome!
Old 02-17-2017, 12:53 PM   #640
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
They ARE the best.
Hahaha. My friend (a welder) always says "Miller for drinking, Lincoln for welding"
I don't know that I could have a preference... I stink!
Big Mac I bought for $500!!!!! M1031 Short-Bus Conversion Projects 110 09-23-2017 02:05 PM
Just bought a bus. What do y'all think?! hello_im_alex Conversion General Discussions 18 04-07-2012 07:41 AM
Just bought a bus!!!!! swinada Skoolie Conversion Projects 4 05-11-2009 07:45 AM
Bought a bus! Abbott Conversion General Discussions 0 07-07-2008 08:18 PM
i bought a bus...now what? abbs681 Everything Else | General Skoolie Discussions 4 07-20-2004 02:01 AM
