Old 12-02-2011, 07:53 PM   #21
pipopak's Avatar
Re: Rolling Motel Room
Originally Posted by wtd
Thanks, now if someone would drop me a tip on how to clean the darned fans that doesn't require Q-tips
Tom
A vacuum cleaner with a round brush attachment. Gone in 60 sec.!
pipopak is offline   Reply With Quote
Old 12-02-2011, 08:02 PM   #22
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
Thanks - I'll give it a whirl.
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 12-02-2011, 10:11 PM   #23
Diesel Dan's Avatar
Engine: DT466/AT545
So, does that heater heat up the whole bus? Or do you have to close off the front half of the bus and just heat half the space to stay warm?
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 12-03-2011, 11:28 AM   #24
wtd
wtd's Avatar
Year: 1982
The whole bus for part of the evening and then just the back half at night - I leave it on low all the time and rather than turn it up I just smallen up the space.
It keeps it about 35-38 degrees warmer than outside on the 'heated' side, this morning was 40 outside and 76 on the heated side of the curtain and 52 on the unheated side when I dashed out to the galley to get some coffee going.So the has just enough leakage to let some heat into the front to keep it somewhat warm.
Also I made another 'thermal curtiain' across the back window -
Just an old bedsheet I had laying around and the the liner is the fuzzy stuff you find in a cheap box spring. It's plenty thick and insulates pretty good. Just sew the fuzzy stuff to the bedsheet, add some snaps across the top, put the other side of the snaps in the wall. Puts another layer between you and outside and stops the drafts I had with just the curtains up.
Easy to put up and take down, Folds up pretty small. I stick it behind the big chair outta the way.
I had heavy curtains up with blinds but swapped out the blinds (don't get me started on blinds in a bus )for roller shades
I got the $4 a piece vinyl ones from Walmart, got 12 yards of duck cloth in the fabric department, came home and took the vinyl off, cut off a 28" long piece off the bolt for each window - the duck cloth comes 36" wide, which gave me the length -sewed rod pockets across one end, the 28" way, attached the duck cloth to the rollers, stuck the rods in the pockets at the bottom and stuck 'em up. You can see thay make a pretty good seal the bottom, they do on the sides as well and stops the drafts I used to have with the blinds.
Kept an eye on the temperatures for the next little while and those two things added about 8 degrees to the inside temp's at night. I like the shades better than blinds, when you're driving and want to keep the window open, just put it all the way up and no string or plastic rod to deal with. Easier to clean too - just take them off the rollers and throw them in with the regular laundry.
Oh, one more thing - for those that cringed about using fabric off of old box springs - they stay pretty clean during their life, since they're under the mattress and the top cover of the box springs, but a trip to the laundromat cleans they right up. Wash 'em by themselves and throw in whatever chemicals you like to kill whatever scares ya'.
Tom
Where DIY meets WTF
Old 12-03-2011, 11:34 AM   #25
browncrown's Avatar
Rated Cap: 79 at Birth
Put roller shades up in mine too...much better than blinds. Really like the work on your thermal shades.
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 12-03-2011, 11:52 AM   #26
wtd
wtd's Avatar
Year: 1982
Thanks, BC - never saw anyone else use roller shades, maybe it's the Kern County air, huh?
Tom
Where DIY meets WTF
Old 12-05-2011, 10:55 PM   #27
Engine: GMC
Rated Cap: 42
"smallen up the space"???!?? LOVE IT!!!!
JA Savage is offline   Reply With Quote
Old 12-06-2011, 04:13 PM   #28
wtd
wtd's Avatar
Year: 1982
Combination of southern herritage and latin in college -figure I can just 'roll my own'
Plus it has a twisted relational, palindromic effect, no?
[en] large || small [en]
Where DIY meets WTF
Old 12-06-2011, 06:46 PM   #29
browncrown's Avatar
Tom
We have the worst air in the nation here in the valley, so yup, that must have been the cause
BC
Old 12-06-2011, 09:36 PM   #30
Chassis: IH
Engine: 466
Rated Cap: 64
Yes, I like your bus alot- and it seems sometimes that less is more! I have tortured my allready challenged mind to figure out the big motorhome look for my bus (when I find it someday) on a dime budget. And then I find this thread and the open space, money saving approach seems to work very well. I can put away those grandiose dreams of a poor man's Prevost and just be simple and happy. I still struggle with the dream of those 'Rolling Homes' of the '70's with the cedar shingles and stained glass windows and fancy tile work, but I guess it just doesn't really matter all that much anymore. Comfort and saving money is more important now.
dburt is offline   Reply With Quote
Old 12-06-2011, 10:41 PM   #31
Engine: GMC
Rated Cap: 42
HA!!!! Love your Lingo! BTW, my hubby noticed in an earlier post somewhere that you are a Travis McGee fan? We were just wondering if you'd got around to building your RollsRoyce pickup yet?? Is that coming up on your "to-do" list???
Old 12-06-2011, 11:17 PM   #32
wtd
wtd's Avatar
Year: 1982
No, no 'Miss Agnes' on the list
But I live aboard my own version of the Busted Flush and I have faithfully, lo these many years, followed Mr. McGee's retirement plan - take your retirement as you go, whenever you can get it and in whatever size chunks you can grab ... life's short. Currently in a retirement phase ...
Tom
Where DIY meets WTF
Old 12-07-2011, 09:03 AM   #33
Stuff's Avatar
that's it! im requesting a video tour! lol
Old 12-07-2011, 03:19 PM   #34
thommassey's Avatar
Chassis: All American RE
Engine: 3208TA Cat 250HP
Originally Posted by pipopak
Very interesting!. I have been planning my own for like a year, with partitions and all, but I like more your "open" approach, so I guess I will head back to the drawing board and see what I will came up with
Ditto...
TUMBLEWEED (AKA Rufus) build:
viewtopic.php?f=9&t=11121
PICTURES : https://s1338.beta.photobucket.com/user/ ... M-HP/Rufus
thommassey is offline   Reply With Quote
Old 12-09-2011, 12:31 PM   #35
wtd
wtd's Avatar
Year: 1982
Just an exterior shot, took this a couple of days ago after I got back from 'Tank Day' festivities over at the airport, empty some, fill some at the RV park there followed by a grocery run.
Pretty much just as it rolled outta North Carolina a few decades ago, the white paint is still the factory paint job, the brown stripes are mine.
The only holes I added (can you add a hole?) were the two RV baggage doors, the 6"x6" hole below the door and a 4"x6" RV style access hatch that you can't see really in this picture, just behind the front wheelwell.
The access door behind the front wheelwell is for the propane lift switch, in the forward 'baggage' compartment carries the system stuff - water pump, etc, the aft compartment hold the generator fuel tank, hoses and junk and the hole below the door is an entrance 'step' for when I don't have the boarding ladder up and is an access point for checking/adding oil in the 5kW generator that sits behind it.
Pretty plain, but I liked the way it looked when I bought it, so tried to keep it that way.
Tom
Where DIY meets WTF
Old 12-09-2011, 02:05 PM   #36
browncrown's Avatar
Nice picture of your bus!
BC
The Roach Motel roach711 Short-Bus Conversion Projects 450 09-07-2021 09:37 PM
rolling again keith Everything Else | General Skoolie Discussions 5 09-16-2012 11:21 AM
Duckf00t bus still rolling Duckf00t On the Road | Travel, Trips, Camp Sites, Tailgates 5 10-18-2009 01:56 AM
Need advice on rolling on paint! KC10Chief Conversion General Discussions 11 08-09-2007 08:11 AM
Looking For Rolling Chasis.. Please Help customstevo Classifieds | Buy, Sell, Swap 3 09-20-2006 11:53 PM
