Old 11-17-2011, 04:38 PM   #11
thommassey's Avatar
Chassis: All American RE
Engine: 3208TA Cat 250HP
Re: "Rufus"
Originally Posted by bus-bro
If you want an all-season bus, strip all the interior metal and have it foamed. Converting a bus is a lot of work and money depending on what you want. It's probably smarter to go quick, dirty, and cheap--and use it. If you want to keep on bus'n, there's always another bus out there. They're cheaper than they've ever been.
Something to consider... Thanks.
TUMBLEWEED (AKA Rufus) build:
viewtopic.php?f=9&t=11121
PICTURES : http://s1338.beta.photobucket.com/user/ ... M-HP/Rufus
thommassey is offline   Reply With Quote
Old 11-27-2011, 12:11 AM   #12
thommassey's Avatar
Re: "Rufus"
Looking for input (or weigh in) on metal thickness for sheeting where I am removing old windows... went to metal yard and, just by feel, 22 gauge seemed right... Also have to consider being able to wrap rear corners... Any experience here would be greatly appreciated...
Also, can't find info on battery recommendations... currently stock the "dead" ones are 2- 12volt parallel 6 cell ( 6 total caps about three battery size in one).
Before spending $$ I want to buy the ones that will do the job... And do I "have to" separate starting battery from others to avoid draw down? Common sense says yes???
Old 11-27-2011, 12:23 AM   #13
thommassey's Avatar
Re: "Rufus"
The wood subfloor over the steel is in great shape... any big disadvantage to leaving it intact? And the plates over the Sending units on the tanks??... are they req'd to stay accessible?
Old 11-27-2011, 12:51 AM   #14
thommassey's Avatar
Re: "Rufus"
Just purchased (for $250 and it works!! ) a 10kva generator that was used as a truck mount generator... Any problem enclosing these and or insulating them?
I will have to install a "gas"tank for it... Gallons? I assume a couple weeks in the desert (most fuel consumption) would be longest w/o refill... Any ideas? Usually won't need a/c... woods, and coastal living.
Old 11-27-2011, 01:00 AM   #15
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
Re: "Rufus"
Common sense wins again! Better if your start batteries are separate/different from your house batteries.
i left my plywood floor, it was in good shape. Patched in about a square foot in two places.
Don't know what you mean by 'required'. I guess if you want access to the sending unit from the top I'd say yes. I have no access panel in the floor for the tank sending unit.
Tom
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 12-01-2011, 09:56 PM   #16
thommassey's Avatar
Re: "Rufus"
After more consideration, this being my first skoolie... a roof raise will not happen on this bus. I really like the look of the front, and I am only 5'9" so it will be fine for me. IF I do another, I may want to do the raise... I really had my heart set on it, but I will be happy with just having the bus...
So I guess next step is to get motor ck'd by my local Truck Repair Co. and, if all is OK, then start the tank installation and welding the generator in somewhere..
I will remove some windows, but will probably keep the originals where needed.
I have some larger RV windows that I aquired, but may have to do some modification to get them in... stateroom.
Need to do some calcs to figure invertor size and battery requirements...
May also include solar panels... not sure on that one.
Old 12-05-2011, 03:36 PM   #17
thommassey's Avatar
Re: "Rufus"
Since I found out today my System is 24 volt( except lighting) do I need to Install add'l generator for house batteries, or is there a way to charge them from the existing "start"batteries? edit~(System is 12 volt)
Old 12-05-2011, 04:08 PM   #18
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: "Rufus"
Are you saying your bus has a 24 volt chassis electrical system? That would be unusual fo a Bird. They do have two 12 volt batteries wired in paralell.
Old 12-05-2011, 08:12 PM   #19
pipopak's Avatar
Re: "Rufus"
A military spec bus would be 24 volt. Unlikely but not impossible.
pipopak is offline   Reply With Quote
Old 12-06-2011, 09:02 AM   #20
thommassey's Avatar
Re: "Rufus"
That is what a mechanic told me over the phone... Today I am gonna crawl under (i.e. ck if it is parrallel or series) and verify.
RIVET vs SPOT/PLUG WELD vs "BOLTS" vs GLUE etc. ol trunt Everything Else | General Skoolie Discussions 2 03-04-2014 11:42 AM
1986 Intl/Thomas Conventional, DT466 5speed, "Big Blue Bus" thrash Skoolie Conversion Projects 8 08-25-2013 11:57 AM
"Short" bus or "Regular" bus? TygerCub Conversion General Discussions 11 03-03-2012 12:37 PM
"Tutorial" and "How To" internal error dunnwright Conversion General Discussions 6 11-16-2010 07:02 AM
