Old 02-25-2012, 11:04 PM   #41
thommassey's Avatar
Chassis: All American RE
Engine: 3208TA Cat 250HP
Re: "Rufus"
New air governor took care of the air leak (good strong 80#'s now at front and rear brakes), then a complete fluids change. Found out I may have to replace some steering components, tie rod ends, bushings (quoted up to $1k) , ouch! Not sure if this is something I should attempt myself, steering and all?? Still working on the overheating problem, I will try fan switches first? then look at t-stats . (Any opinions welcome in this arena).It will run up to overheat (looks to be about 220-240 w/o my glasses ) then come down 20 degrees, then up and down again. Damn overheat buzzer drives ya crazy, but makes a point. Engine warms to about 150 degrees then smoke (exhaust) pretty much is not existent. I Still want to put the exhaust up the top down the road.
TUMBLEWEED (AKA Rufus) build:
viewtopic.php?f=9&t=11121
PICTURES : http://s1338.beta.photobucket.com/user/ ... M-HP/Rufus
thommassey is offline   Reply With Quote
Old 02-27-2012, 09:53 AM   #42
Re: "Rufus"
cat engine should run at 180 or so. Have you checked you gauge/ sending unit against a known temp gauge or point and read temp reader from harbo freight?
you also should determine if your water pump and radiator are in good condition, and that the fan drive assembly which is normally on the driver's side and the clutch fan thing is working properly.
And is your turbo working properly?
As far as front end components, the easier things to change by yourself are the tie rod, drag link, etc ends. If I were going to pay for something, i would just pay for the bushings to be done if its a straight axle and they have to be reamed out. I have changed bushing myself of this type, but i had to buy the proper reamers, and it took me quite a bit of time to do them on a truck.
Old 02-28-2012, 02:37 AM   #43
thommassey's Avatar
Re: "Rufus"
Originally Posted by chev49
...you also should determine if your water pump and radiator are in good condition, and that the fan drive assembly which is normally on the driver's side and the clutch fan thing is working properly.
Little help here, in the meantime I will ck service manuals to see if I can find some info on doing these things... I have no idea how to ck water pump and turbo for proper operation.
Thanks chevy, you have been a big help and have saved me alot of grief (you know, head scratchin' )
Back to it ...
Old 04-05-2012, 02:33 PM   #44
thommassey's Avatar
Re: "Rufus"
Yesterday took her out for a real test run...
Bushings still need to be reworked, temp runs average at 180-190 at full throttle, not sure if that will change in summer ( I like the idea chev 49 gave me about the mister on the radiator during summer) ? It was about mid 50's when I took her out....
There is quite a big rpm decrease from third to fourth gear, almost 1k rpms, and I guess that is good. Ran at 65 mph for about ten miles straight and flat, no heat issues, ran about 2150 rpms+-, air was steady. The air ride seat seems to flatten out at the bottom (yeah I know, less donuts ) so I will read the manual on that, Otherwise pretty happy with mechanical operation. Going to layout tank and plumbing fixtures to see where placement will be, then start windows. Still changing floor plan...
Old 04-05-2012, 02:49 PM   #45
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Re: "Rufus"
nothing like a good leg stretcher for a sitting bus!
Old 06-01-2012, 11:40 AM   #46
thommassey's Avatar
Maiden Voyage
Been awhile, life on life's terms you know!
Well.. finally got to put Rufus on a real road trip. Also got to feel the real joy of camping in a skoolie.
Lots of work ahead of me, but now I am extra motivated to bring her to life again with interior and exterior work, yeah... everything! Running like a top except for some front end work I will have to do, bushings? I think. Lots of catching up to do on older posts... really appreciate you all! Let summer begin!!
Old 06-01-2012, 11:50 AM   #47
browncrown's Avatar
Rated Cap: 79 at Birth
Re: "Rufus"
Great to see you out on the road Looks like a great camping adventure
BC
Old 06-01-2012, 06:29 PM   #48
lornaschinske's Avatar
Rated Cap: 89
Re: "Rufus"
Must have reviews & pictures on the campground!!!! We need to get a campground review section on here.
Fulltime since 2006
Old 06-18-2012, 12:14 AM   #49
thommassey's Avatar
Re: "Rufus"
More pics and info coming this week after computer upgrade
Old 06-18-2012, 10:14 AM   #50
Re: "Rufus"
I heartily second Lorna's motion...a Campground Review section would be invaluable to everyone here. Even better if arranged by state or region, free & paid. I think we could build it over time into something really worthwhile.
RIVET vs SPOT/PLUG WELD vs "BOLTS" vs GLUE etc. ol trunt Everything Else | General Skoolie Discussions 2 03-04-2014 11:42 AM
1986 Intl/Thomas Conventional, DT466 5speed, "Big Blue Bus" thrash Skoolie Conversion Projects 8 08-25-2013 11:57 AM
"Short" bus or "Regular" bus? TygerCub Conversion General Discussions 11 03-03-2012 12:37 PM
"Tutorial" and "How To" internal error dunnwright Conversion General Discussions 6 11-16-2010 07:02 AM
