Old 04-06-2014, 02:41 PM   #1
Engine: Ford B600 6.6 TurboDiesel
Rated Cap: 32
Rust underneath
Hi, my bus has some rust underneath the chasis. None of it seems to be bad, just surface. Im thinking I will attempt to scrape and brush off the rust and paint it to prevent any futher rusting. Any suggestions on what to use?
bbeenn88 is offline   Reply With Quote
Old 04-06-2014, 04:58 PM   #2
Rated Cap: 32
Re: Rust underneath
I tried using wire brushes and thats working but its very slow and hard to get in the corners. Im thinking of buying or renting a sandblaster. Thoughts??
Old 04-06-2014, 07:32 PM   #3
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Re: Rust underneath
Blasting is a blessing and a curse. On one hand it gets all your metal down to the clean shiney, on the other you risk unearthing further rust. I would personally brush off the loose and then treat it with ospho which is a rust converter and then paint. You keep some of the original material in tact that way. And you dont have to rent a blaster, get a large enough compressor, or risk damaging other parts of your ride.
just my .02.
-Doc
Old 04-06-2014, 07:48 PM   #4
Re: Rust underneath
I second the ospho. Just remember to wash any heavy dirt and road grim off and since you are going to be under the bus make sure at a minimum you wear goggles not safety glasses and some rubber gloves like the ones you wash dishes with.
texasrednek is offline   Reply With Quote
Old 04-06-2014, 08:06 PM   #5
Rated Cap: 32
Re: Rust underneath
thanks for the input guys.
The chassis is still solid but there is some rust build up that chips off. How much of this bubbling chip off kind of rust can I spray the converter over? there is so many hard to reach places, thats why I thought of sand blasting. but maybe pressure washing would take enough off to spray the converter on?
Old 04-07-2014, 11:12 AM   #6
Re: Rust underneath
If you have the room to maneuver under there, high pressure washing should blast off anything that needs to come off (loose flakes). Once thoroughly dry, a good rust converter should take care of whats left. Just check the brand you might be considering to see how it is rated. Most are rated only as "primers" in that they require a coat of paint to get the benefits. There are a couple that do not. I have tested and used a product called "Quest Restore" for well over 10 years on the rebar used on my art projects with excellent results. Tried forcing some treated rebar to rust and couldn't. Good stuff.
And, a cheap little siphon type sprayer is great for putting converter on...no needles or moving parts. I run my compressor at about 90-100psi and it blasts the converter way up into hard to reach places.
Good luck with it. Stabilizing any rust is a great place to start.
Old 04-07-2014, 11:27 AM   #7
Engine: 190hp 5.9 Cummins
Re: Rust underneath
Tango's advise with the pressure washer will also have one more added bonus.
Many of the buses if you look underneath, will have a white powder forming in some spots. This is caused by two things.
Salt that has not been washed away, and the venting from a flooded acid starting battery. Both mine had this around wheel wells, and over the battery box.
The pressure washing you give it will wash this all away. Just be sure to let it dry for a day or so in the heat, before applying the rust stop spray.
For the rust stop spray, I like to use a clean new hand pump weed sprayer. They also work good for spraying degreaser, ect.
Old 04-11-2014, 11:45 PM   #8
Rated Cap: 32
Re: Rust underneath
Thanks for the help guys.
Underneath Storage Lacey119 Conversion Tutorials and How-to's 3 08-20-2014 09:35 AM
Rust Buckets norreh1 Classifieds | Buy, Sell, Swap 30 04-30-2014 02:49 PM
Hose from engine block venting exhaust underneath bus? Elliot Naess Mechanical and Drivetrains 3 06-26-2010 11:40 AM
How to mount tanks underneath? Diesel Dan Plumbing, Water and Waste 3 12-14-2009 11:28 AM
de-rusting and painting underneath skoolie_grease Conversion General Discussions 5 04-03-2005 08:42 PM
