I'm still being a slacker about updating this thread. I apologize. Here is another picture dump.
Installation of the basement A/C for the front. The return air is in the step well, the vent is in the floor.
That necessitated moving the fuel tank back 10 inches. While is was out, I cleaned it inside and out, broke the pickup tube, fixed the pickup, painted it and the mount and reinstalled.
I'm still amazed he made the 1000 mile trip home with all this crap in the tank. There were a lot of chunks of goo that I cleaned out.
While the tank was out, it got a new sending unit so the gauge may actually work.
All cleaned up and ready to install.
Tank and A/C hung where they belong.
Vents and grills installed. The flooring will cover up the ugly.
This is the old fuel fill. The cap kind of floated on the end of a hose. It was pretty nasty.
Since I had to move it back 10 inches as well, I made it a little less ugly. The cap is from a Opel GT. Much better looking than a plain old round cap.
There was a change of plans on the rear A/C unit as well. Originally I was going to use another 5K btu unit hung under the bus, but I was worried about having enough A/C down here in the South. So I installed a 12K btu unit instead. It cost me a small cabinet, but A/C is more important than storage.
I had to build a sheet metal pan for the unit to sit in, as well as some dividers for the condenser air discharge. I'm happy to report it works like a charm.
I also came across the new engine and transmission for SanFord as well. I picked up this as auction, for cheap.
That gives me a 6l Turbo Diesel, 5 speed automatic, 27K btu engine driven A/C unit, dual alternators, dual battery boxes, and possibly the entire, modern front suspension, brakes, and steering. I may graft the entire front chassis onto SanFord. There is still a lot of measuring and planning to do there, but the new bus was so cheap I couldn't pass up on it.
He did manage a trip to the gas station for some fresh fuel.
I'll try to keep things updated on a more regular basis. I've got a bunch of projects underway at the moment so things are progressing in fits and jerks, but they are getting done, albeit rather slowly. More to come.
