Old 03-01-2016, 06:08 PM   #51
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Naaa-make it shoot sparks-it looks like the Rocketeer!
Old 03-01-2016, 06:25 PM   #52
Ya...Actually, I am kinda goin' for that Rocketeer look. Now if I just had Howard Hughes money to pull it off right.
Old 03-02-2016, 09:17 AM   #53
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
Big time jealous of some people's metalworking skills!
For AC units, I'm planning to use a couple window units modified to be ducted, putting them under the floor. I'll probably need some in-duct booster fans.
The roof AC I put into the emergency exit is going away, mainly because it leaks and no amount of fighting with it seems to cure that.
I need a 2nd AC for the bedroom anyway, so I figure that will be the test to figure out if I can make the basement AC work, and then I can dump that hog on the roof.
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 03-02-2016, 10:08 AM   #54
Great plan Dan --- Ducted basement units rock. Especially when set up using high efficiency window units
Old 03-16-2016, 05:44 PM   #55
Year: 1956
Chassis: Ford B-600
Engine: Ford Big Block FE
Not a lot has happened in the last few weeks since I've been out of town every weekend.
I did managed a couple of small projects.
Side window replacement is underway. It took some digging to figure out how to get the windows out. Glass has showed up, new rubber glazing has been sourced, and the frames are in primer. I'm hoping to put them back in this weekend.
All the seals and glass for the rear widows is also here. They will also go in this weekend.
The rear door latch consisted of a hasp and padlock. That wasn't acceptable. I wanted to be able to open the door from the interior. I sourced a couple of vintage looking RV latches that are perfect.
The water tank had a couple of places that had been patched. Today I filled it with water and it leaked nicely. A new 40 gallon tank has been sourced and is on the way.
The new tank is a little smaller so I can relocated the water pump to a location I can get to it without standing on my head.
I also pulled and tested the water pump. It runs like a champ.
I have also decided to strip it down the rest of the way for paint. I've picked up a water sandblaster and a couple of hundred pounds of sand to help with that. Here's a short video of how it works.
More to come as it happens...
Toyman01 is offline   Reply With Quote
Old 03-16-2016, 06:30 PM   #56
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
That is awesome! It saves you from having to wear a respirator and a hood! I am so looking up the kit to attach on my pressure washer right now!!!!!
Nice find on the handle!
-Doc
My build thread - viewtopic.php?f=9&t=467197
Old 03-16-2016, 06:52 PM   #57
Year: 1956
Chassis: Ford B-600
Northern Tool carries them for about $70.
Old 03-16-2016, 09:36 PM   #58
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Yea-you got to let us know how that works for you.
I could follow your thread just for the cars that pop up in the background of your pics.
Old 03-17-2016, 11:01 AM   #59
Yeah, I've seen the same vids. That water sand blasting looks like a very effective thing; looking forward to hearing about your experiences with it.
Strange looking water pump! I assume that eccentric on the shaft is connected to some sort of plate in some sort of chamber with check valves into and out of it? The only place I've seen something like that in use was the guy who came to pump out my septic.
dan-fox is online now   Reply With Quote
Old 03-17-2016, 08:45 PM   #60
Year: 1956
Chassis: Ford B-600
Dan-fox, it works just like a mud pump. I hooked it up to a water source today to test the pressure switch so I shot a short video for the interested.
