Old 11-26-2006, 12:33 PM   #81
Sean I hope you don’t feel your thread about your beautiful bus is being hijacked here.
If you’d prefer me or anyone else taking this to another section of the forum , please let us know.
Demon I’ve been thinking about your catapult/counterweight idea and the only way I can think of pulling that off is to do something like that on the back of the bus.
It’d be silly to do it up on the roof and although a person could put it on the side of their bus …I personally wouldn’t.
Although this would work … it would be a problem in the sense you’d have to mess around quite a bit ….figuring out how you were going to secure the pole in an upright position would be a bit of a pain.
Because you couldn’t have anything sticking out that would impede the poles movement. So you’d most likely have to build some sort of catch system that you would attach over/around the pole after you got it in position.
Wow Les …that marine antenna mast holder bracket is perfect for what I want to do….Thanks.
Are you questioning my Aaa-thoritttyy ?
soused moose is offline   Reply With Quote
Old 11-26-2006, 01:57 PM   #82
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
It's all good...I'm digging the brain-storming and tossing around ideas. Great stuff.
Les, I like those fittings too..thanks for mentioning them
Sean
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 07-21-2008, 10:46 AM   #83
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Re: Schoolbus Homestead
I need to set up the bus to tow my motorcycle trailer. Currently, the house batteries are located on the rear deck, which is attached to the frame rails. This is where a receiver has to be mounted, so the batteries get to live inside the bus.
Looking at the new battery location. This is the rear of the bus on the passenger side.
I disassembled the battery box, removed the batteries from the rear deck, cleaned the batteries, and placed them on the floor at the foot of the bed. Lengths of 1" x 2" were then screwed to the floor and bed box to keep the batteries from moving.
I also took this opportunity to reverse the positive and negative of the battery bank, and also to use different batteries as the "terminals" of the series/parallel string. Put another way, I shuffled the batteries.
The box is vented to the rear of the bus with a 12-volt muffin fan from Shaque du'Radio. A screened, 3" hole on the right side of the box allows fresh air entry. The hole where the wires enter/exit the box is sealed with spray-in foam.
A few days after this photo was taken, I installed a voltage-sensing switch to turn on the fan only when the batteries are charging and generating oxygen & hydrogen.
I added gasket material to the sides of the box to ensure a nearly air-tight seal between the box and bus door.
__________________________________________________ ______________________________________________
Next I installed a Class III Valley Industries hitch. This is a variable-width model. Attaches to the bus chassis rails with 9/16" hardware.
Using the 2" x 2" x 3/16" angle iron from the deck support, I relocated the deck to a higher position, and installed a 48-gallon Action Packer box.
3/8" Grade 8 nuts & bolts fasten the parts together, and fasten everything to the bus bumper.
The rear deck is offset from the back of the bus a few inches so the box lid can be opened completely.
This entails a lot of drilling through steel, so there were metal shavings everywhere. A small magnet makes it possible to collect of all of the metal shavings from the work area.
Long spiraling metal shavings tell me that was probably doing things right: using the right drill speed and pressure, a good bit, and cutting oil (20w-50 in this case).
This is a mockup of the trailer in relation to the new deck. I don't think I'll have to use a hitch extension.
Old 09-07-2008, 12:57 PM   #84
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
This past August marked two years of full-time bus-living....w00t!
I decided to update the bathroom to have running water, and also make a change to the composting toilet setup.
The "before" shot. The bathroom, while functional, was left incomplete during the original conversion process. This is looking rearward. Behind the picture-taker is the composting toilet.
Add plywood (11/32nds thickness) to finish the wall, sand and wipe with mineral spirits.
Primer, then paint with oil-based gloss almond enamel.
I'll cut down a beefy Boos maple countertop (1.75" thick!) to fit the available space (26" wide x 16" deep.) A Chicago Faucets spigot will deliver water to the 12" stainless sink. I'm using a foot-pedal valve to turn the water on & off. I'm not a major germ-a-phobe (seriously), but it's always bugged me to turn on water with dirty hands, wash your hands, then turn off the water by touching the dirty handle.
Water service comes in from the lower left corner, via 1/2" pex pipe. Rather than use a bunch of elbows to route the water to the intake of the pedal valve, I decided to make a nice curve and arc it over. It works best to make Incredible Hulk sounds while bending pex this way. The Bill Bixby Hulk, not Ed Norton Hulk.
I screwed the foot pedal valve (mfg by Fisher Faucets) to some scrap 2x4s to meet the required clearances for mounting.
This is a dry-fit of the sink. I screwed 2"x2" lengths of pine to the walls to support the countertop. The left side is screwed to 1/4" birch, so I decided to add more support via a vertical 2x2.
Cutting the butcher block to size left enough material for a nice back splash. I also lopped off the right corner to provide some extra clearance for the narrow bathroom doorway.
I had to find an extra long blade for the jigsaw. Cutting the hole was a lot easier than I'd anticipated.
Two coats of polyurethane later I installed the sink and faucet, and attached the water supply. Works like a charm!
After the photo I added a bead of almond caulk around the perimeter of the countertop.
Now that I have freshwater delivery to the bathroom, I have to figure out how to get the waste water out. I also need to do something to cover the space under the sink. A curtain? cabinets?
Bigger pics here.
Old 09-07-2008, 10:31 PM   #85
the bath counter and sink really look sharp, keep up the good work
Old 02-10-2009, 09:02 AM   #86
Coachwork: genesis
Chassis: international harvester
question for you sean, what size bed are you using & did you just use the mattress or the box spring also, thank you for your help, our bus is kind of like yours except longer & DT466 instead of the DT366.
dieselman69 is offline   Reply With Quote
Old 02-10-2009, 09:18 AM   #87
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
The bed is a Full size, and I just have the mattress on the plywood. Very comfy.
Old 02-16-2009, 06:53 PM   #88
reprobate's Avatar
Love that maple counter top and faucet set-up! Nice looking.
reprobate is offline   Reply With Quote
Old 02-24-2009, 07:53 PM   #89
SeanF
How has that Tiny Tot stove worked out, does it put out any useable amount of heat?
Thanks
Ty
BoonDockGhost is offline   Reply With Quote
Old 02-25-2009, 08:49 AM   #90
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Hi-
Yes, the stove puts out lots of heat. It takes a little while to get up to speed but easily warms the bus (with the help of a fan to circulate the heated air).
But bear in mind I spend winter in the desert so I'm not dealing with really cold temps.
Cheers
Sean
Motorcycle Homestead - Around the World Redbear On the Road | Travel, Trips, Camp Sites, Tailgates 17 10-01-2011 08:08 PM
Schoolbus Graveyards in Virginia kentja Everything Else | General Skoolie Discussions 0 09-04-2010 04:59 PM
1986 GMC Schoolbus britishroamer Classifieds | Buy, Sell, Swap 7 12-04-2007 01:29 AM
The Mobile Homestead soused moose Everything Else | General Skoolie Discussions 0 02-24-2007 02:59 PM
The Mobile Homestead soused moose Everything Else | General Skoolie Discussions 5 04-04-2006 07:57 AM
