Old 12-19-2014, 06:21 AM   #161
Chassis: Amtran
Rated Cap: 71
hum, seems our happy little forum has taken on a new look
"This is my ship...the Nebuchadnezzar, it's a hovercraft."
~Morpheus
The Nebuchadnezzar is offline   Reply With Quote
Old 12-19-2014, 06:43 AM   #162
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I can read it much easier now, I'll say that.
I watched your youtube vid, and I don't notice anything that sounds ominous. Just bus sounds if you ask me.
Old 12-19-2014, 09:26 AM   #163
Chassis: Amtran
Rated Cap: 71
Hey CB,
I didn't post a vid?
~Morpheus
Old 12-19-2014, 09:52 AM   #164
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Ooops, sorry, wrong member!
Old 12-19-2014, 10:32 AM   #165
sucks to be talking about the wrong member ;)
Old 12-25-2014, 08:54 AM   #166
Chassis: Amtran
Rated Cap: 71
Merry Christmas to all my Skoolie friends, thanks for all of the advice.
~Morpheus
Old 12-28-2014, 03:03 PM   #167
Chassis: Amtran
Rated Cap: 71
Remove the floor?
Like most of the newbies here I asked why all of the insistence on taking up the floor, well I discovered how important it is, unless your lucky enough to have a bus from Cali or Arizona, you probably want to have a look at whats underneath,
This is what you will find under a Northeast bus's floor
~Morpheus
Old 12-29-2014, 03:46 AM   #168
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Yup- doing it the easy way is always going to leave the nasty stuff hidden.
The worst of mine is under the roof around the cracked and leaky emergency hatches.
Ospho and a wire wheel are your friend. Keep up the good work!
Old 12-29-2014, 08:56 AM   #169
Chassis: Amtran
Rated Cap: 71
Thank you CB, I looked into Corroseal which recommends application at 45 degrees and above but the Ospho allows down to 36 degrees, which is a help here, I'll have to wait till the end of the week but the temps will rise a little by then. I like the description of the Ospho better too
~Morpheus
Old 12-29-2014, 09:31 AM   #170
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I use ospho then Rustoleum Rusty Metal Primer. Then a topcoat.
I'm planning to apply undercoating to the wheel wells both topside and below to help with some noise.
Still searching for my bus.... Boudreaux Short-Bus Conversion Projects 29 01-21-2012 06:10 AM
Bus searching Seeria Conversion General Discussions 18 08-11-2010 01:04 PM
searching a roof rack oilcan Classifieds | Buy, Sell, Swap 0 03-21-2008 10:25 AM
Searching for my replacement bus Gatorskinz Classifieds | Buy, Sell, Swap 0 12-05-2007 12:48 PM
Searching for the right short bus jenonajourney Classifieds | Buy, Sell, Swap 9 07-15-2005 04:43 PM
