Old 08-27-2014, 07:53 PM   #11
opus's Avatar
Chassis: All-American R/E
Re: Searching for the nebuchadnezzar
I'd find a DT over the 444.
Old 08-27-2014, 07:57 PM   #12
big_bertha's Avatar
Chassis: TC/2000
Engine: Cummins 6CT8.3
Rated Cap: 76
Are you against the 8.3 Cummins for any particular reason?
YouTube | Facebook
big_bertha is offline   Reply With Quote
Old 08-27-2014, 08:40 PM   #13
all you folks talking these "big" engines......can.............f....orget me being involved
Old 08-28-2014, 10:58 AM   #14
Chassis: Amtran
Rated Cap: 71
This is what got my attention about the DT466:
The DT engines are of a wet-sleeve design. This means that the cylinder wall (sleeve) is a separately machined part that fits into the cylinder bores cast into the engine block. The cylinder sleeve is in contact with the engine coolant, hence the "wet"-sleeve.
Navistar claims that the wet-sleeve design enhances durability because the consistent wall thickness of the sleeve allows for consistent heat transfer, ensuring the cylinders stay round during thermal expansion. Additionally, they state that the hardened cylinder sleeve is more durable and wear resistant than a softer, cast-in wall. Also, the replaceable cylinder sleeves protect the block from damage (e.g. in case of foreign objects entering the cylinder) and can easily be replaced, which Navistar claims enables simpler restoration to original specifications. The wet-sleeve design also allows the engine to be rebuilt easily to factory specifications, sometimes without even removing the engine from the vehicle.
I would be interested in hearing what you like about the 8.3 Cummins and your experience with it?
"This is my ship...the Nebuchadnezzar, it's a hovercraft."
~Morpheus
The Nebuchadnezzar is offline   Reply With Quote
Old 08-28-2014, 12:04 PM   #15
opus's Avatar
The 8.3 is bigger and gets better fuel economy than the DT. You cant go wrong with a DT at all! I would not hesitate with a 5.9, 8.3 or any of the DT's. Years ago I drove a DT466 with a 10 spd. Not a huge amount of power but it was a very nice setup.
Generally, the problem with DT buses is everything behind the engine. Transmission and gearing. 8.3's always had a 643 instead of the dreaded 545. I think the 8.3's were mostly used on the big road as a sports bus opposed to most DT's were route buses. Thats just my experiences, I could be wrong, just dont tell anyone.
Old 08-28-2014, 07:01 PM   #16
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
I think one thing people lose sight of how many miles they'll put on their bus a year- 5 years-10 years. Motor X goes 400k between rebuilds-motor Y 800k. I only want motor Y. Hell-400k is 20k miles a year--for 20 years!
I'd worry 1st about good maintance + records-than limiting yourself to just 1 motor.
Where in Ct are you?
Old 08-28-2014, 09:55 PM   #17
Rated Cap: 40 Prisoners
I think that if you do some research you will find that the 8.3 cummins is a wet sleeve
engine as well and you can find some of these mated to the MD3060 transmission which
is a 6 speed transmission but usually limited to 5 speeds by the bus companies but you
can program the computer to open up the 6th gear which is actually a second overdrive.
My Blue Bird All American has the 8.3 and 5.38 differential ratio which gives it good pulling
power on hills but also good economy on the highway. Plus mine has the MD3060R trans
which has a retarder on it for slowing down on long hills to keep the brakes working cool.
From what I've read the Cummins it a million mile motor. Good luck and explore all possibilities.
Old 08-29-2014, 08:50 AM   #18
Chassis: Amtran
Rated Cap: 71
I've noticed that there are a number of travel trailers for sale in my area on CL in various stages of disrepair, I wonder, do many of the members buy these to harvest useful needed components for their conversions?
~Morpheus
Old 08-29-2014, 11:28 AM   #19
there are two basic setups people use
1)buy an rv and strip/recycle it
and
2)Those that go residential
some do combine things like heat(rv propane setups) with a residential type build
Best thing, is you can do whatever floats your Skoolie
good luck with bus search
Old 08-29-2014, 11:57 AM   #20
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Yup- my heater and power supply and some trim came from a used pop up- last project was supplied from a slide in.
Still searching for my bus.... Boudreaux Short-Bus Conversion Projects 29 01-21-2012 06:10 AM
Bus searching Seeria Conversion General Discussions 18 08-11-2010 01:04 PM
searching a roof rack oilcan Classifieds | Buy, Sell, Swap 0 03-21-2008 10:25 AM
Searching for my replacement bus Gatorskinz Classifieds | Buy, Sell, Swap 0 12-05-2007 12:48 PM
Searching for the right short bus jenonajourney Classifieds | Buy, Sell, Swap 9 07-15-2005 04:43 PM
