Old 09-10-2014, 01:07 PM   #51
Chassis: Amtran
Rated Cap: 71
Re: Searching for the nebuchadnezzar
Question: regarding installation of an inverter, the final sentence of what I pasted below mentions moving the 12v converter to the new breaker panel (shore and genset), which I get, but where does 12v come from if not connected to shore or genset?
To do this installation, the shore power/generator cord must be disconnected from the original AC breaker box and connected to a second, smaller AC breaker box installed in the RV next to the original one. This new breaker box will carry only outside power that comes in on that hookup cord: generator and shore power. The new breaker box contains at least one circuit breaker, which passes the outside power to the inverter's AC IN terminals.
One or more additional breakers in the new outside power breaker box may be used for a few appliances in the RV that can not be run on battery based power, because they would quickly deplete the batteries. This might be the air conditioner, and any electric heaters or electric water heaters. These few items must have their circuits moved from the original breaker box and into the smaller second breaker box that carries only generator and shore power. Also the original converter, a type of battery charger built into an RV, must be disconnected from its regular AC source circuit in the main breaker box, and connected to the second smaller breaker box, so the inverter/battery AC source will not operate the converter.
"This is my ship...the Nebuchadnezzar, it's a hovercraft."
~Morpheus
The Nebuchadnezzar is offline   Reply With Quote
Old 09-10-2014, 09:43 PM   #52
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Well thats a lot of type. Let me point out the thing that gets most of my attention. Inverter = 12v to 110, converter = 110 to12v. Quite a few campers and 5th wheels do everything from shore power but all the electronics inside are 12v.
Most of us skoolies want the ability to be unplugged so we use INVERTERS from a battery bank we build ourselves to run our coffee makers laptops and our significant others' hairdryers!
One of the main reasons I got the inverter/charger combo I have is so I can get around having to use a transfer switch if I want. But eventually will have one when I install solar on it.
Hope I am interpreting this right. If someone else sees it differently, please chime in. I would like to know what others think.
-Doc
My build thread - viewtopic.php?f=9&t=467197
Old 09-11-2014, 07:00 AM   #53
Coachwork: ward
Chassis: international
Engine: dt360a
Originally Posted by Tango
Second the Hondas --- I picked up an Eu3000i with one hour on it after hurricane season was over. Can barely hear it run from five feet away but one of it's biggest advantages is that it already has the inverter built in (That's what the "i" on the end means). Clean power for touchy electronics straight off the genny. I know folks who spent as much just on their inverters as I spent on the Honda that already has it.
Also a good point above regarding fuel considerations. I will be carrying diesel for the rig & gas for the genny.
BTW...tested it out on my 8k btu window unit and it never got off "Economy Idle".
hey tango, what is the fuel usage rating on the eu300i and what is it in real usage? thanks
Old 09-11-2014, 09:21 AM   #54
I've only run it off and on to keep it up since it is not yet installed on the bus. However, I had spoken with a few folks who had them for a while and they seemed to agree with the factory projections. Between 5 and 12 hours on a gallon of gas depending mostly on loading. There is a pretty good overview and comparison article on a hurricane preparedness page worth looking over...see it here...
http://<br /> <a href="http://www.hi...ators.html</a>
Old 09-11-2014, 12:32 PM   #55
Coachwork: ward
Engine: dt360a
sounds good tango. thanks for the link!
Old 09-11-2014, 05:18 PM   #56
Chassis: Amtran
Rated Cap: 71
Looks like there are a bunch of different brands of solar panels available, I really don't know much about them yet, are there good ones and bad ones or do they all perform the same function?
~Morpheus
Old 09-11-2014, 11:22 PM   #57
Docsgsxr's Avatar
I haven't gotten that far into the research on them yet but I do know I will shell out the extra money for a single panel 250w or bigger. I don't want a ton of panels on top of the bus with multiple connections and tons of screw holes with the ability to leak later on.
Old 09-12-2014, 08:06 PM   #58
Year: 1977
Coachwork: Chevy
Chassis: C/60
Engine: 350 V8
Rated Cap: 54
In regards to the question about how to wire for a genny and shore power I did something in my fish house because I was low on funds but it ended up working GREAT.
I had the typical 30amp RV plug on the side to which I hooked up a cord to shore power when I used it as a camper. When I was traveling down the road or on the ice I have a Honda eu3000i mounted on the hitch with a second RV style plug in and use a shorter cord I made. I use the same panel inside the house and just flip whatever breakers off I don't want used. Cheap, easy, it works for me and I plan on doing the same thing with the bus if I ever have the need to run off the genny whilst in motion. No auto transfer switches or second panels or anything complicated. Just plug in the front and not the side. Easy.
Passes everything but gas stations.
bamper is offline   Reply With Quote
Old 09-12-2014, 08:12 PM   #59
Chassis: Amtran
Rated Cap: 71
Thanks Bamper, keepin it simple, I like it.
~Morpheus
Old 09-12-2014, 11:00 PM   #60
Simple = Good!
Still searching for my bus.... Boudreaux Short-Bus Conversion Projects 29 01-21-2012 06:10 AM
Bus searching Seeria Conversion General Discussions 18 08-11-2010 01:04 PM
searching a roof rack oilcan Classifieds | Buy, Sell, Swap 0 03-21-2008 10:25 AM
Searching for my replacement bus Gatorskinz Classifieds | Buy, Sell, Swap 0 12-05-2007 12:48 PM
Searching for the right short bus jenonajourney Classifieds | Buy, Sell, Swap 9 07-15-2005 04:43 PM
