Old 09-18-2014, 09:34 AM   #71
Chassis: B3800 Short bus
Re: Searching for the nebuchadnezzar
Originally Posted by Locutus
When using your batteries for power, DC appliances and lighting will be more efficient because you won't have conversion losses, assuming your DC wiring is of sufficient gauge to minimize voltage drop.
While on the topic of wire gauge and voltage loss, here is a nice calculator to figure out wire gauge. Try to keep your voltage loss within 1-3% and you'll be doing great!
http://www.solar-wind.co.uk/cable-sizing-DC-cables.html
As if you needed another resource right now
Old 09-18-2014, 06:15 PM   #72
Chassis: Amtran
Rated Cap: 71
Thanks guys, I actually have that book its excellent, it was that 12v thing that had me confused. So I've been scouting for a generator, I'm thinking diesel would be the best way to go, but they are not as plentiful used as gas. Propane genset seems to be a good option too. There is also quite a bit of room under the bus, I suppose I could install a marine gas tank. What do you use, if you use one?
"This is my ship...the Nebuchadnezzar, it's a hovercraft."
~Morpheus
The Nebuchadnezzar is offline   Reply With Quote
Old 09-21-2014, 04:04 PM   #73
Chassis: Amtran
Rated Cap: 71
The nebuchadnezzar finally came up up on the First Student sale list, will hopefully have him home soon
~Morpheus
Old 09-21-2014, 06:16 PM   #74
sojourner's Avatar
Engine: DT408
A 2 or 2-way fridge does require 12VDC to power the control board. Without it the fridge will not work normally (it can be "hot wired to test though).
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 09-21-2014, 07:03 PM   #75
Chassis: Amtran
Rated Cap: 71
Thank you
~Morpheus
Old 09-21-2014, 08:29 PM   #76
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Good luck on your hunt!
My build thread - viewtopic.php?f=9&t=467197
Old 09-22-2014, 08:36 AM   #77
Chassis: Amtran
Rated Cap: 71
Thanks Doc.
I've been learning about RV electrical systems for my build and there seems to be disagreement regarding pure sine wave and modified sine wave inverters and what you can run using them. The pure is considerably more expensive though probably worth the cost if modified is going to ruin expensive appliances and such. Some folks say that there are very few things that actually need pure sine wave? Any advise would be appreciated.
Thank you
~Morpheus
Old 09-22-2014, 11:01 PM   #78
Chassis: Genesis
Modified sine wave is murder on AC motors. It is not the easiest on switching power supplies either. In short, use nothing you love on modified sine wave inverters.
Timelord is offline   Reply With Quote
Old 09-23-2014, 04:52 AM   #79
Coachwork: ward
Chassis: international
Engine: dt360a
other than fans,and water pump, what else would be considered A/C motor?
Old 09-23-2014, 06:24 AM   #80
actually any electronic digital timers is effected, like microwaves, clocks and coffee pots...never really effected us in the last few years.
turn coffee pot on when we need coffee (don't use timer feature)
really don't care what time it is (microwave clock never gets set)
and the clock we use (very seldom is normally running on invertor)
I always use my laptop while driving off an invertor never a problem (also has the older "brick" charger this makes a difference the internet told me )
the laptop thing I have been doing for years in multiple vehicles and always used invertors (cheap ones also like the B&D 500 watt is a tank and 5 years old probably)
Also have an old aluminum cased no name ~$15 400wt that we run a small crockpot for dip with, it's an antique
and our fridge runs 10 hr days while traveling off the invertor
I have had good luck with modified sine wave invertors, I just never had the extra cash when an invertor was needed, so I always got mod. sine
True sine wave are a lot cleaner in power (I have read)
Also their is an unwritten rule about using 85% of an electronic devices rated output for max life...seems to work that way
I have 2 cobra 3000 watt (1500 nominal) and biggest load it see's is 930 watts (microwave and fridge while on the road)
don't forget to power invertors you need enough 12v amps and the correct wire size to run them, I only use microwave while bus is running (this lets me also use the alt to help power it)
Keep invertors close to batteries (separate compartments) to minimize the big cables you need to feed them 12V
Still searching for my bus.... Boudreaux Short-Bus Conversion Projects 29 01-21-2012 06:10 AM
Bus searching Seeria Conversion General Discussions 18 08-11-2010 01:04 PM
searching a roof rack oilcan Classifieds | Buy, Sell, Swap 0 03-21-2008 10:25 AM
Searching for my replacement bus Gatorskinz Classifieds | Buy, Sell, Swap 0 12-05-2007 12:48 PM
Searching for the right short bus jenonajourney Classifieds | Buy, Sell, Swap 9 07-15-2005 04:43 PM
