I have made some other progress on my bus. I changed things up a bit and decided on a bit more.
I did pick up a Natures Head toilet... expensive for a fancy bucket but I suspect it will be worth it.
The water tank I had planned to use came out of an older wynie along with the grey tank. I decided that the water tank was too tall for what I needed to do and since the shower is still in the highly debatable column I decided to sell the grey tank along with the fresh water tank. Interestingly enough the grey water tank sold very quick and no one buys fresh water tanks!
My new water tank will sit better under the bed and the best price I found was from Amazon of all places. I will link it below so others can look. I also picked up a sureflo pump and acumulator to match.
I started to build the bed but with a slight twist. Since I plan to have the bus for years I know there will be a time when my kiddo wont want to travel with my wife and I. Since my bus has an RV sleeper sofa why not build the Queen bed to be multi-purpose?
I am building the queen frame with a removable mid section that is 3ft wide. This also allows me to bring larger items through the door. By building essentially 2 bench seats with a removable mid section I can at a later date pull the queen bed out and lift the middle as a table and have a dinner table area. This means that we would just sleep on the sleeper sofa if it is just the 2 of us. I think I will sketch something up and show what I mean. Anyhow I started to build that this weekend.
I have a 5 day weekend coming up so I hope to make some good progress.
Picture concept of the bed
The water tank I got from Amazon and Water Pump etc (not installed yet but good reviews)
SHURflo 4008-101-E65 3.0 Revolution Water Pump
SHURFLO (255-213) 1/2" Twist-On Pipe Strainer
SHURflo 182-200 Pre-Pressurized Accumulator Tank
New RV 46 Gallon Fresh Water Tank T-4600 sold by ClassACustoms
