Old 09-22-2005, 11:27 AM   #1
vonslatt's Avatar
Engine: CAT 3208 NA
"Seeker" - 1989 Thomas Pusher - www.vonslatt.com
Though I'd start a new thread now that the bus has been named!
Got my tanks installed, both 92 gallons blackwater and potable water seen below. I've posted the blackwater tank installation here: http://www.vonslatt.com/bus-plumb.shtml and I'll post the rest in a day or two. I'm a little behind as the propane is also done but not posted.
My 1989 Thomas Saf-T-Liner
vonslatt is offline   Reply With Quote
Old 09-22-2005, 12:27 PM   #2
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
Not only is it an excellent installation, but your documentation is excellent, as well. Good job!
The spin-weld fittings are something that people need to be aware of if they buy polyethelene tanks. I was not aware of them, and the company I ordered from didn't mention that installing them took special equipment. I told the company just to send me the tank and I'd locate the fittings. I ended up not being able to install them, so I just cut holes in the tank (potable water tank) and ran pipes in from the top. It works okay, as the holes are fairly tight around the pipes, but I worry about sloshing causing leakage while in transit.
92 gallons is a good tank size, I think. I have a 40 gallon tank, and it lasts me about a 6 or 7 days.
Eric von Kleist is offline   Reply With Quote
Old 09-22-2005, 05:46 PM   #3
You can get a plastic welder at HarborFreight for $30. I have not personally used one though people that have like them.
http://www.harborfreight.com/cpi/ctaf/D ... mber=41592
busone is offline   Reply With Quote
Old 09-23-2005, 08:03 AM   #4
Beautiful Job VonSlatt...
I picked up our big 96 gallon fresh water tank from the same folks you did....
I was going to order the more 'typical' RV style Black water tanks from plastic-mart...but now that I see your install ( using a potable water tank for the Black water one)...
I think I'll do the same on our trailer.
Are you questioning my Aaa-thoritttyy ?
soused moose is offline   Reply With Quote
Old 09-23-2005, 01:32 PM   #5
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
von slat bus
Great Job! I have read through your site a number of times since buying and working on my bus. Everytime I read it another aspect seems applicable.
Point of interest: When I toured the Blue Bird Factory I learned the buses that are used in New York state are generally the most expensive they produce (generally), there are exceptions I'm sure though. At over $100,000 each canadian. They have major saftey requirements. Just thought you might be interested.
-Richard
captainkf is offline   Reply With Quote
Old 09-23-2005, 03:17 PM   #6
vonslatt's Avatar
Engine: CAT 3208 NA
Gosh! Thanks!
More updates today:
Propane: http://www.vonslatt.com/bus-gas.shtml
Kitchen: http://www.vonslatt.com/bus-kitch.shtml
Bathroom: http://www.vonslatt.com/bus-bath.shtml
Almost caught up! I just have to post the finished kitchen cabinets, the potable water tank, and some lighting installation and I'll be up to date.
Old 09-23-2005, 04:03 PM   #7
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
re: format changes
I like the info on where you sourced your material. However some of the text is cut off on the right hand of the screen. Just thought i'd give you a heads up. -Richard
Old 09-23-2005, 07:21 PM   #8
Great documentation, bus is looking great.
Automatic tire chains!!!
I've never seen such a thing, it appears they lower in front of the wheel and spin so they throw themselves under the tire. Is this correct?
Brad Davis
79 International Wayne
"Big Blue"
bdavis441 is offline   Reply With Quote
Old 09-23-2005, 08:36 PM   #9
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Man! I'm gonna have to pull my album outta the gallery until I can post some pics that can keep up with you Jones's!
Hey, but that's some SERIOUSLY nice work you've done there! Ditto on the nice documentation.
Griff is offline   Reply With Quote
Old 09-23-2005, 10:45 PM   #10
vonslatt's Avatar
Engine: CAT 3208 NA
Thanks! These guys have a movie of how a similar system works:
http://www.onspot.com/
Can't wait for the first snow! I want these things on my Towncar but they are only available for 1/2 ton pickup and larger vehicles.
Old 09-24-2005, 07:34 AM   #11
Great updates and really clear pictures !
What kind of camera are you using ??????
Thanks,
Michael
Old 09-24-2005, 08:05 AM   #12
vonslatt's Avatar
Engine: CAT 3208 NA
Thanks,
Michael
I've got an Olympus C-3020 3.2 megapixel camera. It's probably about 3 years old but is was well rated by CU when I bought it. I take the pictures in "Super High Quality" mode and then use "mogrify -resize 320x240 picture.jpg" to reduce it for the web.
Mogrify is part of the free ImageMagick suite of tools available here:
http://www.imagemagick.org
They work best under Linux but there is also a Windows version.
Old 10-03-2005, 11:23 AM   #13
vonslatt's Avatar
Engine: CAT 3208 NA
Update: Bunks, Tanks, Lighting
Recent progess on my '89 Thomas Saf-T-Liner:
Mattresses for the bunks:
http://www.vonslatt.com/bus-bunk.shtml
Potable water tank installed:
Lighting for the Dinette area:
http://www.vonslatt.com/bus-dine.shtml
Jake.
PS: If you are at all into SciFi you MUST go see Serenity
Old 11-23-2005, 11:37 AM   #14
vonslatt's Avatar
Engine: CAT 3208 NA
Hi Everyone,
I made some minor updates today, new pics in:
Plumbing - http://www.vonslatt.com/bus-plumb.shtml
Body & Chassis - http://www.vonslatt.com/bus-body.shtml
and two new pages:
Tools you'll need - http://www.vonslatt.com/bus-tools.shtml
Electronics - http://www.vonslatt.com/bus-tron.shtml
And best Thanksgiving wishes to all !
Old 11-24-2005, 12:59 AM   #15
Your bus sure is lookin nice. I also had one of those Intel branded confrence cameras. I got mine from the trash where I used to work. Turned out they junked it because it did not work. How are you reversing the image from the camera?
Old 11-24-2005, 07:05 AM   #16
vonslatt's Avatar
Engine: CAT 3208 NA
Reversing? Right for left? Do regular backup cameras do that? Honestly, it didn't even occur to me, I expect I'll be doing the reversing in my head. I'll just have to watch out if I ever drive someone else's rig!
Old 11-24-2005, 07:10 AM   #17
how about mounting it behind you so you can see it in the big rearview mirror?
Brad Davis
"Big Blue"
Old 11-24-2005, 07:26 AM   #18
vonslatt's Avatar
Engine: CAT 3208 NA
Clever! The TV could go there on a turntable! I like it!
Old 11-24-2005, 11:30 AM   #19
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
If you ever want a reverse image on a TV, you can do that by reversing the leads going to the picture tube coil (I used to do that, by accident, when I was repairing TVs in school).
I am planning on doing this on my conversion and I'll post pics as soon as I get it done (please don't hold your breath though).
If you feel like you're not qualified to do it yourself, just get a TV tech to do it. The job is simple and shouldn't cost much.
Just remember, you'll be permanently modifying the TV.
Robert
Roasting8 is offline   Reply With Quote
Old 11-24-2005, 02:19 PM   #20
vonslatt's Avatar
Engine: CAT 3208 NA
Ah yes, I should have thought of that, I used to be a TV repairman myself in the late 70's when people still repaired their TVs.
I wonder if a DPDT switch could work? Though at 15Khz lead length would be an issue and you'd be liable to blowup the horizontal output if you flipped the switch with the TV on.
"Terrapin" the 1989 Thomas Skip Skoolie Conversion Projects 29 01-14-2014 01:28 PM
1986 Intl/Thomas Conventional, DT466 5speed, "Big Blue Bus" thrash Skoolie Conversion Projects 8 08-25-2013 11:57 AM
++SOLD++ 1989 TC2000 FE (Calif. CLEAN title, as "MH") chev49 Classifieds | Buy, Sell, Swap 1 02-18-2012 12:10 AM
1990 Thomas Transitliner- "Thomas" Hormone Derange reddog Skoolie Conversion Projects 8 12-16-2010 09:22 AM
1982 Thomas Safe-T-Liner "Illusion" Les Lampman Skoolie Conversion Projects 89 02-28-2007 07:41 AM
