Old 05-16-2016, 11:06 AM   #231
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Test Test Test.
Old 05-16-2016, 11:12 AM   #232
Originally Posted by Stu & Filo. T View Post
Test Test Test.
Sorry but 3 times I typed out a up date & 3 times after clicking on submit I got a error message & lost all my typing.
Old 05-16-2016, 11:29 AM   #233
Finally after many months of life getting in the way i was able to do some work on Senza Legno E Pontilli.
I fitted my 112 gal. Grey tank into position & routed the wires for the level sensor & the pump. I have cargo strap holding it in place for now so I can drop it quickly when i do the final plumbing & no I will not drive it like that.I also routed the 1in line from the grey tank to the Black tank.
Old 05-16-2016, 11:32 AM   #234
Another shot
Old 05-16-2016, 11:36 AM   #235
Can anybody tell me why when I click on advance & then manage attachments it gives me 5 spaces to upload pics but will only load 1??
Old 05-16-2016, 12:09 PM   #236
gmarvel's Avatar
Engine: DD6-71T
Is that the tank from Sequoia?
gmarvel is offline   Reply With Quote
Old 05-16-2016, 12:41 PM   #237
Yes it Greg, lol I didn't think you were still on here.
Old 05-16-2016, 01:03 PM   #238
I also cut & fitted then POR 15 the end pieces for the propane tanks cage. Now if that mean old woman I'm married to will leave me alone I just might get them Installed on my next day off.
: angel:
Old 05-30-2016, 10:42 PM   #239
Ok worked on Senza Legno Senza Pontilli today, have most of the cage around my propane tanks done just a little fine tuning left, Next step is to put in my floor, I have a 1 3/4 in plywood floor that's in great shape, I've already coated it with 2 layers of Red Gaurd, I'm planning on one more layer of the Red Guard then 2x4's down the center with 1 1/2 styrofoam on each side of the 2x4 then a 1/2 in styrofoam on top of that with 3/4 tounge & groove subfloor, question I have is do I put down a plastic vapor barrier & if so where in the process??
Old 06-09-2016, 01:36 PM   #240
Working on my waste plumbing & today I scored this DC powered hose reel off a CalFire water truck, It has a 50 amp DC motor & 1in fitting so should work with my Macerating pump from the waste tank. A little bigger than I needed bit for $140.00 compared to $800.00 plus for a new one I'll live with it.
