Old 06-10-2016, 03:05 PM   #241
Now you can go around putting out fires with your poop tank--cool!
Old 06-10-2016, 04:38 PM   #242
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Naw sounds like a Chitty job.
Old 06-10-2016, 05:43 PM   #243
Fitting it into place, had to leave for work so tomorrow I have to trim off a few inches off the front of the frame of the reel then go a little higher then make mounts for the reel.
Old 06-15-2016, 11:51 AM   #244
Well the reel is in, I also have the plumbing done from grey tank to black & black tank to reel, when I install the mercerating toilet I'll plumb in with a Y fitting into the line from grey to black & install a check valve so waste doesn't back flow into grey tank. Next step is build the control panel.
Old 08-16-2016, 07:27 PM   #245
Well, do to high heat ( I don't do well in extreme temps) a heart procedure/operation I had & now a hand injury I havn't been able to work on
Senza Legno Senza Pontilli, But I did pick up my new plates today.
Old 08-17-2016, 02:13 AM   #246
gmarvel's Avatar
Engine: DD6-71T
Love the retro plate. These are actually easier to see than the new ones, at least in the daytime.
gmarvel is offline   Reply With Quote
Old 09-20-2016, 05:56 AM   #247
Love the plate
Old 10-22-2016, 12:24 PM   #248
Finally, got some work done,since my black tank is mounted behind my right rear wheels I realized a plastic tank just wasn't going to cut it so I took a 112 gal fuel tank cut it in half long ways then trimmed another 3 in off the top half, welded in a 1 1/2in pipe for attaching the mercerating pump then welded on a 1/4in plate for the bottom. Got it mounted up almost looks like it was meant to be there.
Tank measures 60" x 20"x 7". I'm thinking about 30 to 33 gal capacity??
Old 10-22-2016, 06:59 PM   #249
AlleyCat67's Avatar
Year: 2005
Engine: Detroit MBE906
36.36 gallons if it's a perfect rectangle. Since the top and bottom are rounded it will be somewhat less so your 30-33 guesstimate is probably about right.
Old 10-22-2016, 07:02 PM   #250
I'd add a pic but the site doesn't work
