Old 10-16-2013, 10:16 AM   #21
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Re: No bastoni, no chiodi ricurvo a due punte
Asking for opinions, neighbor suggested that instead of pulling the panels off the ceiling & re-insulating I should just pull the roof vents off & see if there's any evidence of mold or leakage, if not then just glue carpet to the panels already up there. What do you think?
Old 10-17-2013, 12:05 AM   #22
gmarvel's Avatar
Engine: DD6-71T
I VOTE NOT TO TAKE OFF THE HEADLINER
We took our interior vents off our Crown and found that the two inches between the outer and interior roof areas are packed with insulation. I thought I had been told that Crowns had no insulation in the roof. Obviously, I was wrong. This is very good news. The last thing you want to do is remove hundreds if not thousands of rivets and screws. The framing above the headliner is a web of structural metal designed to support the roof from caving in if the bus rolls over or drops on its roof. It is designed to support 1.5 times its weight if the bus falls upside down (I think from a drop of 20 feet). We intend to put a layer of thin insulation on the interior headliner and then place flexible paneling covered with padding and a high grade vinyl with the look and feel of leather. We believe it will provide sufficient additional insulation and will dampen the exterior and interior noise.
Taking the headliner completely off and then putting spray foam insulation within all the honeycomb compartments up in the roof would certainly be the best option for total insulation value. However, the headache, sweat, tears and carpal tunnel syndrome you would get is not worth it, in my opinion.
Crown roofs are like no other. They are made to last. Dismembering them can be done. But, the cost is too high for the value received, since the roof is already insulated. You have the same model year as my Crown and I have full insulation. The only thing I don't know is if roof insulation was an option, so some late model Crowns might have it and others might not. I just don't know. People with more knowledge about that will have to weight in.
______________________
Greg and Donna Marvel
Danville, California
http://www.transtraks.com
gmarvel is offline   Reply With Quote
Old 10-17-2013, 12:37 PM   #23
Year: 1974
Engine: Detroit Diesel 6-71
I second this and really really hope we have an insulated roof also. We'll be checking that out here shortly.
These buses are built like brick sh#$ houses. Our original plan was to pull the roof down, until we got a crown. I think heavy curtains and a wood stove will do us just fine...
Proud new owners of a 1974 Crown Supercoach - the big rolling twinkie!
viewtopic.php?f=9&t=466562
inkblots84 is offline   Reply With Quote
Old 10-19-2013, 11:04 AM   #24
Well it's been 1 week since I brought the Bus home, gutting the interior is a slow process only have the right side done so far, feels like I've ground off 10,000 rivets so far only 100,000 more to go, got the seats all broken down going to take this morning & load all the padding & cushions into the truck so I can take them to the dump
Old 10-19-2013, 11:05 AM   #25
Nice to hear the term "we"
Old 10-19-2013, 11:06 AM   #26
Unless it's a mouse in your pocket
Old 10-19-2013, 11:07 AM   #27
is "she" down with the bus yet?
Old 10-19-2013, 11:09 AM   #28
Well the wife is still out of town, she's back east helping her parents with some health issue's their going thru so it's not like she's staying away on purpose but she calls every day to hear about the progress
Old 10-19-2013, 11:26 AM   #29
Gotta give the little lady credit tho, I've been a bachaling man for a week now & boy does the house show it
Old 10-20-2013, 09:57 AM   #30
After loading up the truck I stepped into the bus to clean up a little & I had left some windows open & I find a Humming bird had flown inside & couldn't find his way out, poor little guy was so tired from beating himself against the windshield that he crawled right into my hand & let me carry him outside.
