02-10-2014, 05:43 PM
#101
Coachwork: Crown / Pusher
Re: Senza Legno, Senza Pontilli
So what thickness of metal do people like to skin with?, talking sheet metal distributors here some recommend 18ga, some say 20 ga will be fine
02-11-2014, 11:16 AM
#102
I agree ...try to match what you have around the windows. And if you are riveting or welding directly you can avoid "oil canning" by pre-heating the sheets and keeping them around 125* (about the same as a hot shower) until secured at several points. A small propane torch is more than adequate. Never put sheet metal on "cold". The first time it warms up and expands you will not like what you see.
02-14-2014, 10:44 AM
#103
I've decided to go with .040" aluminum for skinning , what do you think of these rivets?
http://www.rivetsinstock.com/rivets/bli ... ivets.html
I know I need to but a barrier between the 2 different metals for corrosion purposes
02-14-2014, 12:58 PM
#104
Steel & aluminum need to be fully insulated from one another. Any area of contact is essentially a battery and both will oxidize very rapidly.
02-23-2014, 11:04 PM
#105
Not a whole lot to report, I did get doublers installed over the ribs this weekend
03-09-2014, 01:52 PM
#106
Trying to work on the bus but between work & the rain not getting very far, just wondering tho would treating steel & aluminum with por 15 be adequate for protection between dissimilar metals?
03-09-2014, 09:29 PM
#107
Nat is absolutely correct. You need total isolation of dissimilar metals and the Butyl tape is one of very few solid solutions. Anywhere they come in contact you have electrolysis and very rapid destruction of both metals.
03-17-2014, 07:01 PM
#108
Well, I was welding in the supports for the fwd section & the wire feed stopped working on my welder, the drive wheel doesn't move & I can hear something clicking, any quick ideas?
03-17-2014, 07:28 PM
#109
Oh & it's a Lincoln 125
03-17-2014, 09:09 PM
#110
Well I'm on hold until I get it working again, as far as doing a good job welding I discovered that purchasing a auto darkening & adjustable shade helped a lot in being able to see my work , not saying professional grade but a co worker who is also a licensed welder here on aircraft said they looked good, I do need to practice welding thin materiel a little more
03-21-2014, 11:05 AM
#111
Great more delay, threw a disk out in my back yesterday, cant move heading to chiropracter later today
03-21-2014, 11:18 AM
#112
Chassis: bluebird
Rated Cap: 16
Love your roof raise.
Backs are overrated. Surely there's something you could be doing while laying on the floor?
03-21-2014, 11:38 AM
#113
Yes, stare at the ceiling I'd laugh but it hurts
03-21-2014, 11:39 AM
#114
And thank you
03-21-2014, 08:07 PM
#115
I was working on tying in the fwd section before my welder & back quit on me
03-22-2014, 03:35 PM
#116
omg this build looks great need more its like a soap . Days of our bus.
03-23-2014, 08:30 PM
#117
LOL thanks, or "as the bus turns", or As the Bus Burns" Or as my wife just said "The Nightmare On Albany St"
03-24-2014, 07:02 PM
#118
lol for sure
03-26-2014, 12:05 PM
#119
okay it's been 6 days, you fixed yet?
03-26-2014, 12:52 PM
#120
Moving around better but now it's raining so had to recover the bus plus my welder has not been returned yet
