05-25-2014, 10:07 PM
#161
Coachwork: Crown / Pusher
Re: Senza Legno, Senza Pontilli
Well 2 days of working in 96 deg heat & this is how far I got, Saturday was just the wife & I we got the right side up & most the riveting done, I worked from 6am until 8pm & I'm burnt, Sunday had the son of a fried of mine come over with a buddy of his & by 2pm all the panels are hung but not all secured I had run short of butyl tape & can't get anymore until Tuesday so I'm a good 1/2 way done on the drivers side,, I'm using 18g steel in 10 ft sections with VHB tape on the ribs where there is no lap joint, 3/4in rivets on ribs with lap joints & 3/16 rivets spaced 1&1/2 in across the bottom going to only work on it a few hrs tomorrow them spend some alone time with the wife
05-26-2014, 05:13 PM
#162
Engine: 3126
It was in the upper 90's when I did mine. I planed that on purpose. I hope with the steel heated and then riveted, I will have less buckling of the steel (Oil canning) in the summer.
05-26-2014, 10:47 PM
#163
I understand what you saying, But, my leggs are burnt , my back is burnt , my face is burnt , my neck is burnt, other than that pretty happy with what was accomplised this weekend
05-27-2014, 05:53 AM
#164
Engine: 3126
I'm almost as good as nat, I have an answer for all you issues, suntan lotion.
05-27-2014, 09:41 AM
#165
I did use sunsreen
06-26-2014, 04:13 PM
#166
Still working on it just a bunch of little detail stuff
08-12-2014, 01:11 PM
#167
Been to hot to work outside so I have been doing things to the house but I did just make a photobucket account & uploaded the photos there
http://s1049.photobucket.com/
09-06-2014, 11:19 AM
#168
Pulled the Bus out today , getting back to work on it , somethings I got accomplished that took my time away
Installed new front entry door with security door
Installed 8 prehung solid core oak doors
Installed Oak trim around the doors & base boards in a few rooms
Plus been helping a buddy re raise a barn that partially collapse because his son wants to get married in it this October
09-20-2014, 11:48 PM
#169
Year: 90
Coachwork: blue bird
Engine: Navistar Straight 6 Turbo
love your conversion. hope you don't mind if i take some (a lot) of your ideas and use them in mine.
“Twenty years from now you will be more disappointed by the
things that you didn't do than by the ones you did do. So throw off
the bowlines. Sail away from the safe harbor. Catch the trade winds
in your sails. Explore. Dream. Discover." Mark Twain
09-21-2014, 10:08 AM
#170
Use what you can, I'm a giver plus most my idea's so far have come from other builders here
10-02-2014, 08:51 PM
#171
So I'm working on building a cap from fiberglass from the raised to lower portion onmy bus, I'm up on the roof sanding & my neaghbor says " hey your getting dust on my sar" I say "thats ok I don't mind"
10-02-2014, 10:26 PM
#172
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Alternitive response: "Well if you were up here helping, YOU could get dust on your car!"
10-02-2014, 10:28 PM
#173
I like the way you think
10-02-2014, 11:49 PM
#174
Engine: DD6-71T
Stuart, you are doing a great job with your roof raise. It is going to look awesome. I can't wait to see the finished product.
10-08-2014, 05:28 PM
#175
Was able to pop off the fiberglass cap today before it hit 95deg, now that it's on the ground should be able to work on it easier & in some shade
10-12-2014, 08:41 PM
#176
Chassis: TC2000 RE
Engine: 8.3l Cummins
I am envious of the weather, it is just starting to not cooperate over here in the Pacific Northwet.
12-01-2014, 01:32 PM
#177
Finally able to test fit
12-01-2014, 03:54 PM
#178
That should make an excellent pattern for cutting out some sheet metal to weld on.
Just foolin!
12-02-2014, 01:00 AM
#179
Using cinch straps is exactly the way in which they install the roofs on new buses today!
12-02-2014, 05:25 AM
#180
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
