Old 06-03-2015, 07:27 PM   #11
Engine: 190hp 5.9 Cummins
Looks great.
Mine will have something similar, custom made from aluminum by me.
Old 06-03-2015, 10:34 PM   #12
Did I miss where you tell us it's a Chicago area bus? I'd be very interested in the source, I'm in the suburban area and hunting.
wrhby85 is offline   Reply With Quote
Old 06-03-2015, 11:14 PM   #13
RHOMBUS's Avatar
Chassis: Freightliner HDX
Engine: CAT 3126B250
In Kankakee, IL. Just a little hop south. Midwest Transit.
RHOMBUS is offline   Reply With Quote
Old 06-03-2015, 11:18 PM   #14
Thanks, Rhombus. And thanks for the link to the electrical system...I'm going to be up all night geeking out on it!
Old 06-03-2015, 11:24 PM   #15
RHOMBUS's Avatar
Oh it gets addicting. Be sure to thoroughly check the buses out, including a test drive. None of them will be perfect. I selected mine in February and it was just too cold to crawl around under the thing. I sorta wish I had. If you aren't familiar with how a diesel should sound, smell and feel, bring someone who does.
Can't wait to see what you get! When I first started looking, I wanted a Crown, but I was looking for the biggest bus I could get on 2 axles. I quickly reduced my search to just Thomas HDX / Transit RE buses. From there, it's CAT or Cummins and other options.
Old 06-04-2015, 12:20 AM   #16
excited to watch your progress. congrats!
Emidd27 is offline   Reply With Quote
Old 06-04-2015, 04:15 AM   #17
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Old 06-04-2015, 08:31 PM   #18
RHOMBUS's Avatar
LOL, EastCoastCB. I Serenity Now'd my hammer down the middle of the bus because I bashed my finger earlier.
Old 06-08-2015, 05:27 PM   #19
RHOMBUS's Avatar
I have a few moments to make an update... as my cat eats the original dried up electrical tape from the harnesses... HEY !! !!
It took a little longer than expected (doesn't it always) but I finally have the wires removed that will be in the way of the front end work. The driver's chair had to be removed by cutting the bolts out, as well as the seatbelt bolts at the floor. All of the wood flooring in that area was still wet! I think it rained over a week ago and seriously doubt any trickled inside. The result was just a mess of wood particles. It all came up relatively easily though.
I found a great little 1/4" plastic valve at the Runnings in town for $7.50 to shut the air off to the chair and door. Not that it matters a whole lot since there is probably next to no air in the system by now.
Now I have room to start cutting out pieces and see how bad it is. I guess I should remove some air system components that are just below the floor as well.
I still need to get those step pieces out.
I ended up with something like 8 free wires going through the bulkhead connector which might get put to good use in the future. For now, it looks like I'll be getting into the air system to get it out of the way.
Is it worth it to get aluminum air tanks? My steel ones have a decent amount of surface rust on them and I'd feel a lot better if they were replaced. Do you think replacement is even necessary?
Old 06-11-2015, 10:36 AM   #20
all those wires were unnecessary Wow
lousot is offline   Reply With Quote
