Old 07-05-2015, 01:13 AM   #31
Engine: 190hp 5.9 Cummins
I like the "Drip Edge" you had formed into the bottom of each panel.
I used a stiff steel wire with a hook bent into the end to pull the insulation out. The fiberglass would not pull, it just broke into bits every 3 inches or so.
High pressure water will also blast the insulation out of the ribs. Water also eliminates the dust issue.
Old 07-05-2015, 04:00 PM   #32
RHOMBUS's Avatar
Chassis: Freightliner HDX
Engine: CAT 3126B250
Finished mounting one side, need to start on the other. I'll do all the drilling, screwing and sealing this coming week since I have little time off from work.
There are two screws holding each panel in place for now.
I want to develop a bold design for the intake and exhaust, but since they both happen here at the rear passenger side, I'm not sure I can really do much. Hmmmm
RHOMBUS is offline   Reply With Quote
Old 07-10-2015, 03:23 AM   #33
Sure you can, right through the roof.
Old 07-13-2015, 11:48 AM   #34
crazycal's Avatar
This passed me on my way through New Mexico. No need to thank me. LOL
I'm hungry!
You Gotta Let Me Fly
Old 07-13-2015, 12:31 PM   #35
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Anymore need to be said?
M1031A1 is offline   Reply With Quote
Old 07-13-2015, 04:53 PM   #36
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
It's not opening for me
Old 07-14-2015, 09:15 AM   #37
RHOMBUS's Avatar
Not seeing the picture there, crazycal, unless that's the point ;)
Old 07-14-2015, 09:28 AM   #38
crazycal's Avatar
I saw it when I posted it but didn't last night. Might have been a glitch. I can see it now but I will repost.
I'm hungry!
Old 07-14-2015, 09:51 AM   #39
r_w
I have seen lots with chrome stacks off the back corners. Engine one side, genny venturing stack on the other.
r_w is offline   Reply With Quote
Old 07-14-2015, 11:34 AM   #40
Are you saying it was a bad idea??
