10-23-2018, 08:52 PM
Year: 2006
Short Bus to shaved ice bus conversion.
11-27-2018, 03:20 PM
Year: 2006
11-29-2018, 04:58 PM
Year: 2006
Made a little progress today.
Custom serving window still isn't ready...
Still looking for ideas to strip all the reflective decals off to prep for paint.
12-11-2018, 11:54 AM
Year: 2006
The floor is in!
I have to wait 24 hours for the adhesive to cure before I do anything else.
Sink package ordered.
I have all the pieces to install roof ac, I just need to get some help for that project.
01-05-2019, 01:34 PM
Year: 2006
01-28-2019, 02:23 PM
Year: 2006
AC installed. Batteries and inverter are installed. All electrical wire are run to the breaker box. I will get someone to wire the breaker box, that is beyond my limited electrical knowledge. I have a Honda 3000 watt inverter generator that will sit in the middle of the cargo rack between the batteries.
Started to prep for paint. I found these abrasive wheels for a grinder that work great for removing the reflective decals that were all over the bus. I still have a lot of sanding to do before we start taping things off for painting.
01-28-2019, 02:49 PM
is that an armstrong thick vinyl sheet floor by chance?
01-29-2019, 11:05 AM
Engine: 6.0L Gasser
Nice work so far! I have a 2003 with the exact same body. I'm fighting with the floor rails now, and am trying to hit them with penetrating oil and will follow with an impact with a hex bit. Did you try this or simply found out they were seized beyond hope? I'm hoping I don't need to drill out the 200+ bolts holding them in...
01-29-2019, 03:32 PM
I have found that most rusty old nuts & bolts tend to want to stay where they are. So when the refuse to "loosen"...I just "tighten" them with a high torque driver till they snap off. My 18 volt Hammer Drill Driver will do most but my ancient, corded Milwaukee Hole Hog has sheared 1/2" bolts. Just hang on tight.
Course that often means needing someone to hold the other end in place to keep it from spinning.
01-29-2019, 07:19 PM
Coachwork: 1991 bluebird
Look up striping eraser on Amazon for stripping the reflective striping and lettering.
03-19-2019, 12:58 PM
Year: 2006
03-19-2019, 01:01 PM
Year: 2006
Sorry for the delay in responding. I drilled out all of the bolts. I probably went thru 20 or more cobalt drill bits. There are some good ones on Amazon for a decent price.
Year: 2006
Www.checkeredfloor.com is where I got the flooring.
03-19-2019, 01:05 PM
Year: 2006
03-19-2019, 01:06 PM
Year: 2006
This is what worked for me. The eraser was not harsh enough for the reflective decals.
03-19-2019, 04:22 PM
Rated Cap: 35
those reflective decals were a PITA. heat gun and plastic razor blades did the job for me. build is coming along great!
03-19-2019, 05:28 PM
Year: 2006
Interior shelf installed.
I'm going to put the cash register on a shelf just underneath the stainless steel shelf. I need to order a few cables.
The weather is getting nice, I see a paint job in the near future.
03-24-2019, 03:35 PM
Year: 2006
03-24-2019, 04:13 PM
Year: 2006
Coachwork: Eldorado - 210 Aerolite
Looking good
05-19-2019, 06:34 AM
Year: 2006
