Old 04-27-2015, 11:02 AM   #121
Chassis: MVP
Engine: CAT 3116
Awesome conversion, looks great!
Piersg is offline   Reply With Quote
Old 04-27-2015, 12:05 PM   #122
Love the programmable sign.
jawa01 is offline   Reply With Quote
Old 04-27-2015, 08:19 PM   #123
LuckyChow's Avatar
Coachwork: Phantom
Chassis: Gillig
Engine: Series 50
Thanks everyone. I appreciate the kind words. I think it's good to see different ways of doing things from a lot of different folks. You never know when you're going to pick up a great idea you never thought of before.
I've really learned a lot from the folks here (especially from Nat!) about wood stoves. That's something I've not been around much in earlier years. Hope to have one someday. I also learned tons of info from boat sites about composting toilets, which I also want in the bus by next year. No matter how experienced you are, you can always learn something from someone that's been down the road a few more times than yourself!
LuckyChow is offline   Reply With Quote
Old 05-15-2016, 11:24 PM   #124
sammy's Avatar
Coachwork: Gillig
Chassis: Phantom Schoolbus
Engine: Detroit Diesel 6v92TA
Do you happen to have any more details on the shower? I've got an 88 Gillig Phantom (school bus, not transit) and I'm planning on doing a step-down shower as well. I don't have the rear stairs to build it into, but I think I can just cut away the floor and with a little welding, create a lower flower section that gives me an extra 6-8 inches or so of headroom for the shower area, and still keeps it above my gray water tank. what size and where do you have your gray water tank?
sammy is offline   Reply With Quote
Old 05-16-2016, 08:31 PM   #125
LuckyChow's Avatar
Coachwork: Phantom
Chassis: Gillig
Engine: Series 50
You should be able to build framework to support the shower pan below the floor assuming nothing is in the way below it. My shower pan is stainless and custom made to fit the step well. It turned out to be very expensive simply because I couldn't use a premade shower pan and the custom job cost me about $350. The other mistake I made is that I didn't make the bottom with a slight angle, so it doesn't drain well if the bus is off level (and they are always off level). Next time I make one, I'll make sure it's got some pitch to it. Your grey water tank should be where ever it will fit. Your bus is likely very different below the floor than mine. The transits have a very large fuel tank and a ton of other crap under them. My greywater tank was shallow, but wide. Not ideal, but you have to play the hand you've got.
Old 05-16-2016, 08:46 PM   #126
sammy's Avatar
Coachwork: Gillig
thanks for the photos. I like the idea of the custom stainless shower pan. Not sure I can swing that much money, but it does make for a super-clean looking install! Still have a long ways to go before I get to that point I guess.
Old 05-16-2016, 08:59 PM   #127
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
I can only say wow!
Old 05-16-2016, 09:20 PM   #128
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Originally Posted by LuckyChow View Post
So, do you have to wait for the green light before you can run the shower?
Captain Obvious on deviantArt
Old 05-17-2016, 08:29 PM   #129
LuckyChow's Avatar
Coachwork: Phantom
Chassis: Gillig
Engine: Series 50
Ha Ha! Good one about the green light!
Don't ask me why I left those stickers on ----- I just did. It's a reminder of a galaxy far, far, away.
I made a skoolie group on Facebook BBTC2K Conversion General Discussions 27 11-10-2013 09:30 AM
1986 Ford Diesel skoolie runs great Das Mel Classifieds | Buy, Sell, Swap 3 05-10-2013 10:01 PM
Skoolie on cover of Bus Conversions Magazine BusNut Conversion General Discussions 9 10-16-2009 06:45 PM
A GrEaT tour for a new skoolie... drchefscott Everything Else | General Skoolie Discussions 0 02-08-2009 08:28 AM
Great place to park your skoolie rabiznick Everything Else | General Skoolie Discussions 5 04-30-2006 09:16 AM
