12-31-2013, 11:33 AM
#241
Re: skoolie days
Bansil, I've got to agree--Duramax mmmmm. I've had several. low torque made up for with LOTS of smoke
12-31-2013, 05:09 PM
#242
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Re: skoolie days
Hubba hubba!
04-23-2014, 02:27 AM
#243
Re: skoolie days
Where did you get your awning? I'm hoping to find one minimum that size.
04-23-2014, 07:22 AM
#244
Re: skoolie days
It was just **** ass luck, it was advertised on our radio website. never will find another one for that price, or in this town.
04-23-2014, 08:21 AM
#245
Re: skoolie days
well hopefully I can find the same amount of luck you guys did at some point! haha
04-23-2014, 07:58 PM
#246
Re: skoolie days
well the weather been getting a better, and I have been doing some work on the bus, looks like I'm going to need some steer tires, and maybe injectors, Going to put the new flooring in and a few other things. got a 3 week trip planned this summer, and lots of other trips planned, will post pics of some improvements. but plan on more trips and less working.
06-23-2014, 08:13 PM
#247
Re: skoolie days
well today I started to replace my black water holding tank, it cracked at the 3 inch discharge outlet , it was a 23 gal tank, and I'm replacing it with a 39 gal tank, this time I will use a rubber fernco to connect the 3inch pipe to the drain valve, I'm sure the road vibration caused the tank to crack.
Have to get the bus ready for the up and coming road trip.
new and old tank
this is where the toilet is, its hard to see but the tank is right below, straight drop into the tank
06-24-2014, 01:40 PM
#248
Re: skoolie days
heres a picture of the old tank where its broken
pain in the butt, to replace, I'm sure the road vibration caused this, but on the plus side a bigger tank will be nice
06-24-2014, 05:10 PM
#249
Re: skoolie days
I was asked to show some pictures of my aircondtioners
front one is a 9000 btu portable type, I have 2x3 lumber screwed around the base to keep from moving, and a metal strap around it as well, on the back I got a furnace take off duct boot square on one end mounts to the exhaust , and then goes to 5 inch round out the side of the bus, works good,
front of a/c
exhaust hook up
this is the vent out the side, I don't have the screen on it
the rear a/c is just a reg 5000btu window model just cut hole and installed no biggy, and works great
06-25-2014, 01:54 PM
#250
Coachwork: Honey Badger RV Co
Chassis: tc2000
Engine: 5.9 cummins
Rated Cap: 74
Re: skoolie days
Thanks
06-25-2014, 09:35 PM
#251
Re: skoolie days
GB, that's how i am doing my living room A/C too, originally it was out the window and looked horrible. I finally got sick of looking at it and went out and purchased a hole saw.
Did you use a hole saw? the last one i tried to cut wandered like crazy! looks good!
06-25-2014, 10:13 PM
#252
Re: skoolie days
thank you
and yes I used a 5 inch hole saw, it has a pilot drill bit so there's no wondering, just hang on to the drill its a big hole to saw out.
I also don't like the look of window a/c, but for the back of the bus I can live with it.
06-27-2014, 05:33 PM
#253
Re: skoolie days
well I got lots done on my up black tank up grade, I got the drains valves hooked up and made new mounting brackets, I don't have my welder here so I have to wait till t to tomorrow to finish them, but I did get the toilet back in and put a new flooring in as well
here is the top of the black tank looking down where toilet flange fits, drilled 3in hole
this is the 3inch threaded adaptor glued to the flange that gets glued to the tank. then screw the toilet flange to that, couple screws in the floor , bolt toilet
and here it is and it even works once again
now just have to get the tank mounts and finish the mounting
07-09-2014, 07:55 PM
#254
Re: skoolie days
well got the oil and filter changed, as well as the fuel filter, getting ready for a 4000km trip (give or take)
Got the rear a/c changed out old one puked , picked up some beaded seat covers the work ok keep your back from sweating to the seats
rear a/c inside
out side a/c
and the fancy new beaded seat covers
07-31-2014, 09:23 AM
#255
Re: skoolie days
well made it back after being on the road for 16 days in the bus, did 4100kms all went well, the old bus ran like champ ,
I have some pictures to post later on, had a great time, got to see the grandson
07-31-2014, 10:37 AM
#256
Re: skoolie days
glad trip went good!
07-31-2014, 09:28 PM
#257
Re: skoolie days
ok here are some pictures
heres the bus where we boondocked at a rest stop along lake superior
another view of the bus
it was nice to wake up to this view
We have logged 21,000kms on our bus since we owned it, and it seems the road trips are getting better and better
I really want to encourage other skoolies to get out and use your bus, and enjoy the ride.
08-01-2014, 05:48 AM
#258
Re: skoolie days
thank you, we are looking forward to our annual coast run....2 months too go
08-02-2014, 11:18 PM
#259
Re: skoolie days
Thanks for reminding us why we go to all the trouble. Great site and pix. I second getting out on the road. Now I just need to pull all these stray parts together.
08-03-2014, 08:00 AM
#260
Rated Cap: 79 at Birth
Re: skoolie days
gbstewart]
Beautiful pics and great advice! Looks like a wonderful trip!
